Author Topic: 1967 B body 8 3/4 housing back braced.  (Read 618 times)
Offline KillerBee
« on: April 13, 2014 - 09:20:17 AM »
1967 8 3/4" B body rear end housing.
 54 1/4" flange to flange
 44" between the center of the spring pads.
 The housing was built by a professional race car fab shop.
 It was cleaned and sandblasted.
 It was put in a jig and made straight.
 Then a back brace was welded in.
 The spring hanger pads were wrapped and completely welded for strength.
 It has not been used since built.
The 1967 B body housing is roughly 2" narrower than a stock E-body and is the easiest way to get larger tires and 15x10 wheels (with the correct offset) completely under your car.
It is a direct bolt in when used with Dr. Diff's bolt in offset spring hanger kit.
http://www.doctordiff.com/e-body-offset-spring-hanger-shackle-kit.html
What you see in the pictures is what you get.
It's ready for axles, seals and a center section which are not included.
This would be a perfect start for that narrow bulletproof rear end that will bolt in your E body with no cutting or welding.
Add your current 8 3/4 center section and some $300 Dr. Diff heavy duty B body axles or have your current longer E body axles cut down and you're ready to go.
$300 or reasonable offer.
Located in N.E. Ohio 44646
No shipping.
Tmcconn624@sssnet.com
« Last Edit: July 06, 2014 - 10:18:27 PM by KillerBee »
Offline KillerBee
Re: 1967 B body 8 3/4 housing back braced.
« Reply #1 on: July 06, 2014 - 10:17:58 PM »
Price lowered to $300
