The broadcast sheet can be located in various locations: under the backseat, under the driver or passenger seat (this is where I found mine), in the back of the driver or passenger seat (you need to remove the hard seatback), or in the headliner. When you find it you will want to double check it has the correct VIN as sometimes the wrong broadcast sheet was placed in the car.
