Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
1971 cuda firewall coolant hole size
« previous
next »
Print
Pages: [
1
Author
Topic: 1971 cuda firewall coolant hole size (Read 990 times)
culp71
Full Member
on:
April 14, 2014 - 08:58:48 AM »
hello all, on a 1971 cuda 340 shaker (no AC) what is the size of the holes in firewall for both coolant hoses?
(upper and lower diameter)
Logged
4Cruizn
Administrator
C-C.com Expert
HEMI FISH
Re: 1971 cuda firewall coolant hole size
Reply #1 on:
April 14, 2014 - 10:46:07 AM »
Without measuring . . . I would say they look like 1/2 inch pipes. But let's have someone measure and get a correct number . . .
Logged
anlauto
Permanent Resident
I'm Alan G...I'm a Mopar Addict
Reply #2 on:
April 14, 2014 - 12:58:56 PM »
The heater core should have one 1/2 hose and one 5/8 hose. I would guess the two holes in the firwall are both the same around 1''
You're missing your shaker cable hole though...
Logged
culp71
Full Member
Reply #3 on:
April 14, 2014 - 01:11:00 PM »
around 1 it is. (very observant about missing shaker cable hole....not my car, just a goggled pic for reference)
ill cut both holes to 1 inch inside diameter then.
thanks
Logged
AARTA340
Sr. Member
Reply #4 on:
April 14, 2014 - 01:28:04 PM »
This may help also. THis picture shows that one may be slightly smaller than the other. Another with the shaker hole.
Last Edit: April 14, 2014 - 01:31:36 PM by AARTA340
Logged
anlauto
Permanent Resident
Reply #5 on:
April 14, 2014 - 01:54:05 PM »
I have to agree..the holes do look slightly different size.
Logged
culp71
Full Member
Reply #6 on:
April 14, 2014 - 03:06:16 PM »
yes, it would appear (and previously thought) that top hole is larger then bottom hole.
anyone have precise measurements for these, I don't really just want to guess, or cut huge holes.
Logged
CudamanTom
Resident
Reply #7 on:
April 14, 2014 - 05:27:03 PM »
I just measured the holes for the coolant tubes (my engine and my heater box is not installed so as to get precise is easily done).
The top hole is 1"
The bottom hole is 7/8"
Precise
Logged
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
culp71
Full Member
Reply #8 on:
April 15, 2014 - 08:21:55 AM »
excellent, thank you, top 1 inch
bottom 7/8, done.
Logged
CudamanTom
Resident
Reply #9 on:
April 15, 2014 - 09:38:07 AM »
And to add, I was looking at the thick tube insulators that go between the box and firewall and you probably could get away with the bottom hole being 1" as well, as long as the tube is centered with the hole. If that matters from buying another drill bit.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
