Author Topic: Challenger T/A exhaust tip Question  (Read 3129 times)
Offline anlauto
« on: April 15, 2014 - 03:47:03 PM »
On a Challenger T/A the exhaust tips hang from a hanger mounted to the inside of the rocker panel.
What is the correct hardware for mounting this hanger ?
Offline Got JOB
  • Member since 2-14-06
Re: Challenger T/A exhaust tip Question
« Reply #1 on: April 15, 2014 - 04:09:37 PM »
Looks like 3 sheet metal screws
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline anlauto
« Reply #2 on: April 15, 2014 - 04:37:14 PM »
I kind of thought that too....I restored an AAR a while back and that's all it had. I assumed at that time that it was just been monkeyed with....I thought maybe the factory T/A's had threaded weld nuts in the rocker and used machine thread bolts?
Offline Got JOB
« Reply #3 on: April 15, 2014 - 04:45:14 PM »
I will go out to the shop and take one out and see. I have never had the tips off. I know that my 71 vert has 3   1/4 in holes on the inside rocker on each side like the bracket for the T/A.
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline Got JOB
« Reply #4 on: April 15, 2014 - 04:53:49 PM »
Machine thread bolts and nutserts.
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline anlauto
« Reply #5 on: April 15, 2014 - 05:30:29 PM »
Anyway to get a picture ? What size thread ? what type of bolt ?
Offline Got JOB
« Reply #6 on: April 15, 2014 - 06:01:20 PM »
I will take some pics Wed. and post them. If you have a 1971 challenger chassis manual, look in the exhaust section and it shows the assembly diagram for the T/A  exhaust.
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline DODGE1933
« Reply #7 on: April 15, 2014 - 09:16:49 PM »
Sorry to just bust in, but these are off my TA. Hope they help. The bolts appear to be 1/4-20.
DODGE1933
aka. Mike
Offline anlauto
« Reply #8 on: April 15, 2014 - 09:18:35 PM »
Excellent 1 ...and the rocker has nutserts?
Offline Got JOB
« Reply #9 on: April 15, 2014 - 09:34:20 PM »
Those look the same as mine. Thanks for the pics.  Alan, I assumed nutserts because the rockers on my 71 had the holes and no nuts behind.   Maybe Mike will look at his since they are off.
Ricky
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline anlauto
« Reply #10 on: April 15, 2014 - 09:40:59 PM »
Ricky
Yea, I've seen plenty of rockers in my days with actually 5 holes in a semi-circle....I always thought they were for some type of drainage, they disappeared sometime in 1972...Now it's all starting to make sense...
Offline DODGE1933
« Reply #11 on: April 15, 2014 - 10:07:36 PM »
I am pretty sure it is some sort of nutsert. The car is at the body shop and I'm not going to go see it until next week. If you can't find an answer by then I'll take a look.
Offline Got JOB
« Reply #12 on: April 16, 2014 - 10:37:47 AM »
My mistake. There are no nutserts, actually looks to be either nuts or a threaded plate that covers the three holes behind the rocker. Reason I say a plate is that I took a screwdriver and I could move the threaded item thru the holes and because the  three threaded parts were off center the holes just a bit.
Ricky
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline cordodge
« Reply #13 on: April 16, 2014 - 07:07:49 PM »
I think your right ricky, I remember working on one years ago that had some rust issues and if my memory is right there was some kinda plate or the rocker was doubled up in that area or something like that.not 100% sure, memory is not what it used to be
   bruce
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline burdar
« Reply #14 on: April 16, 2014 - 09:44:51 PM »
The fastener guide shows the same bolts as above.  (6) 1/4-20 x .62" hex head SEMS bolts with paint cutter and pilot point.  Phosphate finish.  They have an EL with a circle around it on the head.
The fastener guide doesn't say anything about nuts or a retainer plate for the bolts.
