Author Topic: sloppy/floppy dash vents  (Read 639 times)
Offline ff6849
« on: April 16, 2014 - 01:37:24 AM »
My A/C dash vents just flop close when I try to use the my A/C any tricks to make them stay in place when you try to adjust the air flow direction........... After 40+years they have seemed to lost their desire to fight any air current
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Offline 72cudamaan
Re: sloppy/floppy dash vents
« Reply #1 on: April 16, 2014 - 08:29:03 AM »
There is a little tension clip on the pivot pin on the left side of each vent. It probably broke, but visual confirmation
is best. Not sure where to get a replacement other then maybe another vent from the junk yard.
If I cant fix it, it's broke
Andy  (phukker whither)
