1971 Plymouth Cuda
Author Topic: 1971 Plymouth Cuda  (Read 9587 times)
Offline 1bad340
1971 Plymouth Cuda
« on: April 18, 2014 - 10:28:13 AM »
It is a true 340 4 speed CUDA car from the factory but does not have the original engine. It has a very peppy 360.  Only 1141 were built with 340 4 speeds.
This CUDA was completely disassembled and put on a rotisserie. Everything was restored or replaced.
I have a nice stack of restoration receipts and loads of restoration pics. The receipts provide significant insight into what it took to bring this ‘CUDA to its current state.  I added a extra pic to show what it looks like with Magnum wheels.  The car comes with the billets.
Factory Features:
2 door hardtop Special
340 4bbl, 275 HP
Dodge Main, Hamtramck, MI
VIN: BS23H1B204583
V6W   Longitudinal Stripes, White
26:   26-inch radiator
EN2   End of Codes Assembly Line 2
M88   Low deck lid molding/1/4 panl tape treatment (not sure which)
N41   Dual exhaust
N42   Chrome dual exhaust tips
N85   Tach
R11   Music Master AM radio
J25   3-speed variable wipers
J45   Hood pins with lanyards
J54:   Sport hood
M21   Roof Drip rail moldings
M25   Wide sill molding
M31   belt & hood molding
GB5   Bright Blue Metallic paint
SRX9    Trim Grade: Sport, vinyl and leather bucket seats
000    Upper Door Frame: full door panel
BO6   11/06/1970
009038   Order number
E55   340 4bbl, 275 HP
D21:   HD 4-speed manual transmission
Body:
The body was completely stripped to the metal. Including the bottom! A beautiful Bright Blue Metallic base coat clear coat paint was applied. This is a very straight car. Underneath is base coat clear coat. Yes, I wax it!
It has all its original sheet metal except valances. Very little body work was performed.
New Parts:
All windows
Go-wing spoiler Best quality!
Sport mirrors
Window whiskers
Road lamps with Mopar road lamp switch
Stainless steel trimmed grill.
All grill and headlight hardware
Fender louvers
Door handles and locks, trunk lock.
Marker lenses
Bumpers
Hood Pins and cables
Wheel opening molding, New and chromed!
Polished stainless steel exhaust tips.
All LED lights except the head lights and front parking lights.
Front parking light assemblies and lenses!
All body gaskets, rubber seals.
Restored:
All stainless sanded and polished to a mirror.
Re-chromed tail light grills.
Restored tail light lenses
Inside doors, roof, floors all painted and Dynomatted.
Roof has insulation combined with Dynomatting.
Engine , Transmission,  Rear end
360 engine build by Bobby Joseph Racing. At the wheels 276 HP 340 Torque.  Motor (estimated) 325 HP, 400 Torque
2000 miles
New Parts:
Edelbrock Performer Intake
Keith Black Pistons
Holley 750 Carburetor
Lunati Cam
Mallory Distributor
Magnaflow 3” Polished Stainless Steel exhaust
Summit Ceramic coated Headers.
Dual electric fans
Radiator
Timing Chain & Gears
Wiper motor, washer reservoir/pump
Hard parts (starter, alternator, fuel pump, etc.)
Nostalgic Air  A/C system. Custom stainless steel A/C lines
Engine & transmission mounts
Centerforce Clutch, Pressure Plate, T-Bearing
Hayes Flywheel
Clutch linkage parts
Fresh rebuilt transmission - A833 4 speed 18 spline
Rebuilt 3.23 Sure Grip Posi rear end
Chasis:
New Parts:
Suspension, steering, torsion bars
Leaf springs and shocks
Sway bars
Front disc and rear drums brakes.
All new brake parts, lines, e-brake cable,
Power brake booster
Wiper motor
All electrical wiring bumper to bumper
Speedometer cable and gear
Gas tank and lines
Rebuilt steering
Axle bearings
Wheels/Tires:
Wheel Vintiques Mopar Ralley Wheels
Front 17 x 7 with Dunlop Direzza DZ101s 225/50
Rear  17 x 8  with Dunlop Direzza DZ101s 245/45
Interior:
The interior was completely restored or replaced.  Seat frames were sanded and re-enforced to a higher level than factory.  Dynamat sound deadener was installed everywhere it would stick.
New Parts:
Leather front buckets (PUI),Seat cushions
Carpet
Arm rests
Headliner
Re-chromed Hurst shifter with new pistol grip handle
Shifter boot and trim ring.
Leather wrapped Tuff steering wheel.
Dash woodgrain overlays.
AM/FM/CD Pioneer stereo w/4 Kicker speaker system
Window cranks and door handles
Sill plates
Ignition switch and wiring. Voltage limiter & harness
Package tray
Restored
A/C Dash and speaker grills.
Ralley gauges and quartz clock kit.
Door panels, kick panels
Seat divider and padding.
$67,000  Rick.  Car is in Woodstock, GA
« Last Edit: May 06, 2014 - 09:44:01 PM by 1bad340 »
Offline anlauto
Re: 1971 Plymouth Cuda
« Reply #1 on: April 18, 2014 - 04:06:43 PM »
VGW is most likely V6W which would be white bill board stripes which would increase the rarity by about 200% :drool:
Offline turbo224
« Reply #2 on: April 18, 2014 - 05:04:42 PM »
Good looking car, I'm liking the gold/bronze color under the hood.
~Tyler Larsen~Salt Lake City
-1971 Plymouth Cuda 440-6pk Tribute
-1992 Dodge Daytona IROC R/T
Offline 1bad340
« Reply #3 on: April 24, 2014 - 10:33:13 PM »
Thanks for the heads up Anlauto.  I just looked a little closer. There is a little pimple of corrosion(I guess) on the middle part of the digit that makes it look like a G. I guess it does look like a 6.  I need to step back and have this professional checked. I don't want to monkey around and ruin it by scraping.
I'll keep you posted.
Thanks for the compliment turbo224.
Offline ToxicWolf
« Reply #4 on: April 24, 2014 - 10:41:01 PM »
Try a magnifying glass. It really helped me.
Offline ec_co
« Reply #5 on: April 25, 2014 - 01:10:14 PM »
you can also try a reverse rub pencil on it - flip it over and do the rub. the backside sometimes has less corrosion and can make code ID easier
'70 Barracuda /6 3spd BH23C0E
If at first you don't succeed, skydiving is not for you
Offline tommyg29
« Reply #6 on: May 01, 2014 - 09:53:44 PM »
Wow!
Beautiful car.
Personally, I would have preferred hemi orange under the hood, but the gold sets it apart.
And that interior. Awesome. Makes me think I need to get rid of my console. Something about that shifter and rubber boot draws your eyes to it.
GLWS.  :2thumbs:
« Last Edit: May 01, 2014 - 09:58:12 PM by tommyg29 »
Offline 1bad340
« Reply #7 on: May 05, 2014 - 10:38:55 PM »
Hey guys,
Thanks for the tips.  I pulled the plate and looked at the backside.  It is V6W.
I'm curious though, has any seen a blue 71 with black interior and white billboards?
How "or" can I confirm this config and the production count?
Thanks!
Offline ec_co
« Reply #8 on: May 05, 2014 - 11:21:45 PM »
sounds like a cool color combo to me. no way to tell on production #s for color combinations, ma mopar didn't keep great records on those things.
Offline Dr. Feelgood
  • 1970 Challenger R/T #XXX666
« Reply #9 on: May 06, 2014 - 10:24:14 AM »
Geez that interior is niiiiiiiice!
Offline BS27R1B
« Reply #10 on: May 06, 2014 - 02:30:04 PM »
All the breakdowns were recorded, this provided information and feedback as to what sold and what did not sell. The problem was records were lost and destroyed for a number of reasons. Chrysler was also not flush with cash in the 70s and 80s and room to store everything was minimal. Parts and records were often disposed of due to the lack of space. A few employees and those on the fringe saw some value and grabbed what they could but most was destroyed.
' objects in the review mirror may appear closer than they are ' Jim Steinman
Offline 1bad340
« Reply #11 on: May 06, 2014 - 04:00:39 PM »
got it. Thanks for the compliments and advice!
I dug through the old pics that came with the car when I bought it.
From this high quality polaroid  :o it appears the rear marker lights have the white painted trim. It appears this combo may be correct and they just removed the billboards.
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #12 on: May 06, 2014 - 06:50:29 PM »
Go get some white billboards on that thing!!  Would look so awesome!
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline stinger
« Reply #13 on: May 06, 2014 - 11:02:06 PM »
Beautiful car! Just curious why it doesn't have the typical"cuda" trim on it?
Offline ragtopdodge
« Reply #14 on: May 07, 2014 - 12:08:36 PM »
Were the holes in the tail panel for the trim welded up?
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
