Author Topic: Broken valve spring  (Read 9369 times)
Offline shadango
Re: Broken valve spring
« Reply #60 on: May 31, 2014 - 04:30:07 PM »
As for replacing them all or one, I think it'd be a false economy to roll the dice again by changing just the one. My thinking goes along the " if one failed, how far ahead is the next one" road.
The saying  "I told you so...." would be appropriate here.....LOL    :bigsmile:
Offline shadango
« Reply #61 on: May 31, 2014 - 04:32:20 PM »
I will be following this thread...looks like I need to replace my valve seals, and hopefully thats all.
Sometime during the week I will be removing the rocker shaft and need to pick up a spring compressor tool.
Never done it before so....
Good luck to you too Shadango.  :2thumbs:
FYI, I had done the first one with the help/guidance of my father-in-law.....the latest one I did myself...fueled by being pissed and upset....and it was easy as pie.....of course my guess is that cylinder #7 and 8 will be harder due to location......
Offline shadango
« Reply #62 on: June 01, 2014 - 08:53:56 AM »
While the reading room this morning i was perusing a mopar mag and came across a but that said that valve springs need to be broken in.  The suggested way to do it was to run the engine to normal temp at no more than 2k rpms and then let it cool to room temp....says that this will prolong spring life....
You guys do this?
Offline Strawdawg
    • Vortex Buicks
« Reply #63 on: June 01, 2014 - 09:25:19 AM »
Comp suggests that technique.  Of course they also suggests running a new flat tappet cam up to 2500 rpm on break in but I suspect the extra rpm really does not hurt as it is still low.  The idea is to "heat treat" the springs to improve longevity.
Offline shadango
« Reply #64 on: June 01, 2014 - 09:46:16 AM »
Seems like that is something they could do at the factory, doesnt it?
Offline Strawdawg
    • Vortex Buicks
« Reply #65 on: June 01, 2014 - 09:47:50 AM »
It sure does. Not sure why the customer is the final qc point
Steve
Offline shadango
« Reply #66 on: June 05, 2014 - 12:42:08 PM »
I went ahead and did it.  Just to be safe.
I did google the concept and it seems that some spring manufacturers do heat treat on their end.....so who knows.
Couldnt hurt.
