Author Topic: 2 Carbs  (Read 1790 times)
2 Carbs
« on: April 20, 2014 - 11:20:06 AM »
The forum consensus seems to be QuickFuel or Proform.
I'm looking for an 850 mechanical secondary carb so I've narrowed it down to a QuickFuel Black Diamond QFT-BD-850 or the Proform PRO-67201
The QFT has a choke, proform doesn't. Other than that, any advantages of one over the other? I don't know enough about carbs to know which
is better for me
Car is a 440, 4 sp, 3.55 gears, street car, never seen a track. Has a lunati 703 cam, stealth heads, performer rpm intake.
Offline Strawdawg
    • Vortex Buicks
Re: 2 Carbs
« Reply #1 on: April 20, 2014 - 12:19:22 PM »
if you drive in cold weather, I would prefer the choke but others will tell you to be patient and let it warm up first  :D
Re: 2 Carbs
« Reply #2 on: April 20, 2014 - 01:08:10 PM »
That's really what it boils down to.
I had a non-choke carb for a short period of time. I ran out of patience waiting for it to warm up.
Offline cudabob496
Re: 2 Carbs
« Reply #3 on: April 20, 2014 - 04:27:18 PM »
On my 850, cut the choke tower off, and is still pretty easy to start
and get goin down the road.  Just have to have everything else dialed in.
2011 Kawasaki Z1000
Offline 72cudamaan
Re: 2 Carbs
« Reply #4 on: April 20, 2014 - 05:21:51 PM »
Scott, the proform 67214 has a choke and flows the same cfm.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline blown motor
Re: 2 Carbs
« Reply #5 on: April 20, 2014 - 07:39:11 PM »
I have a choke and I don't think I would want to be without it. You live a LOT farther north than me so I think it's a no-brainer.
A lot of guys on here like to fiddle around with their carbs. It also seems like there is a lot of setting issues with Holley and some of the others and if you want to play with it that's fine. I don't know a lot about them. I have an Edelbrock. Set it and run it. It got set up when we redid the engine and I haven't touched it since. It starts great and runs great. I have friends that feel the same way. So maybe it comes down to what type of guy you are. Do you want to play around the carb or just set it and forget it?
Just my  :2cents:
Re: 2 Carbs
« Reply #6 on: April 20, 2014 - 10:49:32 PM »
Typically I found that as long as the car is driven on nicer days you have to play with the throttle for approx. 5 mins & it will idle fine after that without the choke , choke can help cold starts obviously but can also waste fuel & foul plugs if they are on for too long ,
Re: 2 Carbs
« Reply #7 on: April 21, 2014 - 11:48:20 AM »
Thanks for the feedback!
So except for the choke there isn't really any significant difference between the two?
More or less the same carb with different branding/colour?
Offline Strawdawg
    • Vortex Buicks
Re: 2 Carbs
« Reply #8 on: April 21, 2014 - 01:34:49 PM »
Quickfuel and Proform are virtually identical using the same parts...which ever is cheapest would be the best deal, I think.
Re: 2 Carbs
« Reply #9 on: April 21, 2014 - 04:25:12 PM »
the adjustability & performance will be good with either , choke is your call
Re: 2 Carbs
« Reply #10 on: April 21, 2014 - 05:18:02 PM »
K, thanks everybody  :2thumbs:
Re: 2 Carbs
« Reply #11 on: April 21, 2014 - 05:24:29 PM »
my Quickfuel does not have a choke . Works great for me!  :2thumbs: I find a choke unnecessary as I don't drive it when cold anyhow. I do start it up now and then in the winter just to keep things oiled up.
http://www.quickfueltechnology.com/carburetors-q-series/q-series-carburetor-850cfm-drag-an.html
Re: 2 Carbs
« Reply #12 on: April 24, 2014 - 10:28:05 AM »
Well I decided on the proform 67215 street carb.
Appreciate everybody's feedback. :cheers:
Offline cudabob496
Re: 2 Carbs
« Reply #13 on: April 24, 2014 - 06:49:50 PM »
If its real cold, and don't have a choke, put a hairdryer on the intake
for about 15 minutes.  Gets it nice and warm, and startup is easy
because the fuel is atomized better, than it would be if intake
is cold.
2011 Kawasaki Z1000
Re: 2 Carbs
« Reply #14 on: May 03, 2014 - 07:35:50 AM »
And then had a last minute change of mind and bought the Quick Fuel BD-850
http://www.quickfueltechnology.com/carburetors-black-diamond-series/black-diamond-ss-series-850-cfm.html
