Author Topic: 74 Steering Column  (Read 1263 times)
Offline Pentastar Pete
74 Steering Column
« on: April 20, 2014 - 06:48:11 PM »
The upper bearing in my 74 Challenger steering column sounds like its grinding. Im guessing it's the upper bearing, I think there is only one in there. Does anyone have a break down or some pics of their 74 columns?? It is a floor shift auto.
Not sure if I have to pull it to change the bearing, hope not...
Thanks.  :wavingflag:
74 Rallye Challenger
73 Rallye Challenger
68 Charger RT
Re: 74 Steering Column
« Reply #1 on: April 20, 2014 - 11:01:39 PM »
It is relatively easy to get to , pull the wheel & crush can , remove the turn signal arm & lift the switch out of the way , undo the 4 screws & pry the upper housing off of the shaft & the brg is right there
« Reply #2 on: April 21, 2014 - 07:14:54 AM »
So I take it there is only 1 bearing inside the column ?   Thanks CP..  :cheers:
68 Charger RT
« Reply #3 on: April 21, 2014 - 08:13:52 AM »
Yes just at the top , thereis a thread here about adding a second one at the bottom as well if you want to
Offline CudamanTom
« Reply #4 on: April 21, 2014 - 09:19:01 AM »
Here is the thread on that lower bearing Chryco was talkin about.
http://www.cuda-challenger.com/cc/index.php?topic=91398.0
I just did this over the weekend. Very easy if you have the column pulled and took apart.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: April 22, 2014 - 01:39:45 PM »
I have a great PDF document that shows how to disassemble and reassemble the steering column.
A member here put it together a number of years ago.  It is very detailed.
I can send it to you if you would like.  Just PM me your email address.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #6 on: April 22, 2014 - 02:03:45 PM »
Cuda jas your inbox is full! Lol
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline CUDA JAS
  • vroooooom!
« Reply #7 on: April 23, 2014 - 08:53:24 AM »
 :thinkerg: :thinkerg: :thinkerg: :thinkerg: :thinkerg:
Cleaned it out!!
Thanks.
74 'cuda 360/727
« Reply #8 on: April 24, 2014 - 04:45:23 AM »
Sent PM   Tks Jason
68 Charger RT
« Reply #9 on: April 24, 2014 - 07:56:56 PM »
I believe the credit for that would go to Mike - Topcat.
Offline CudamanTom
« Reply #10 on: April 25, 2014 - 06:57:34 AM »
And I thank Mike for that same info.
I just rebuilt my steering column per Mike's PDF and painted it last night. Awesome instructions!!!  :2thumbs:
Thank you Mike!!!  :worshippy
Tom
