Author Topic: Steering Box Leaking on top?  (Read 739 times)
Offline EMCD
« on: April 21, 2014 - 10:06:40 AM »
The round top of the steering box has fluid pooled near the top. the box is a napa reman unit. i'm running a GM pump. could it be too much pressure causing the box to leak? or, do napa units suck?
Re: Steering Box Leaking on top?
« Reply #1 on: April 21, 2014 - 04:28:57 PM »
I assume you are talking about the upper nut where the steering column connects to the shaft if so it is a bad rebuild not too much pressure , I would clean it up & look for the leak though
Offline 1971Challenger
« Reply #2 on: April 27, 2014 - 01:04:02 PM »
I had a similar issue last year. Turned out to be a pinhole in my power steering line and it was leaking at collecting at the exact same spot. Might want to check your hoses / lines, not a bad idea anyway, good luck   :)
"Understeer" is when you hit the fence with the front of the car. "Oversteer" is when you hit the fence with the rear of the car. "Horsepower" is how fast you hit the fence. "Torque" is how far you take the fence with you.
Offline 1970A-66Challenger
« Reply #3 on: April 27, 2014 - 07:01:04 PM »
I had the same problem with a reman'd autozone box. Underneath the round part of the box there is an o-ring. It was pinched/split in my case. Replaced o-ring, no more leaks.
