Author Topic: Painting the engine  (Read 1156 times)
Offline chongo25
Painting the engine
« on: April 21, 2014 - 05:05:29 PM »
Thinking about taking the Slant 6 out and painting the engine to make it look better and clean it up a little. Any suggestions on how to go about getting it prep to go?
Thanks
Offline dpcd67
Re: Painting the engine
« Reply #1 on: April 21, 2014 - 05:18:07 PM »
If you are removing the engine, are you also rebuilding it? If not, why take it out? Degreasing an engine is the most important thing to do when painting an engine and if it is being rebuilt, the shop will hot tank the block.  You can use a pressure washer to remove grease and dirt. Once free from all grease and oil, it is easy to spray on engine paint.
1963 Dodge M37 (3)
1967 Dodge WM300 (2)
1971 Plymouth Duster
Bought new in '71; I wanted the Challenger but they were $2850; too much $ so I got the 318, 3 speed on the floor, Twister Duster for $2100.
1973 Plymouth Barracuda
I ain't done yet.
Offline blown motor
« Reply #2 on: April 21, 2014 - 10:29:37 PM »
 :iagree: I repainted mine this past winter. We took off mostly everything except valve covers. Then did a little masking. It looks great. We didn't get down low on the block. If we missed anywhere else you can't see it anyway.
Offline footin70rt
« Reply #3 on: April 21, 2014 - 10:44:53 PM »
East Off oven cleaner makes a great engine degreaser. Once it's clean and free of grease, shooting it first with some self etching primer will make the paint stick better and last longer.
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline chongo25
« Reply #4 on: April 23, 2014 - 02:56:04 PM »
Sorry i haven't responded back, I'm not planing to rebuild the engine as of yet, I was wanting to just clean up the engine compartment, but with the suggestions of the you guys on here I will give the degrease with the engine still in a try.
Offline Haddixj
« Reply #5 on: April 23, 2014 - 03:15:14 PM »
What also works good is a roll of quarters and simple green and a car wash place. Works even better if you can find hot water
Offline dpcd67
« Reply #6 on: April 23, 2014 - 08:49:06 PM »
If you are leaving in the car, just buy some engine degreaser (or oven cleaner) and take it to a car wash.  Take a putty knife too as the really caked on grease/oil/dirt won't be cut by the degreaser. Might have to do it a couple of times.  Mask, spray; voila; new engine. Well, a pretty one anyway.
1963 Dodge M37 (3)
I ain't done yet.
Offline chongo25
« Reply #7 on: April 23, 2014 - 11:59:25 PM »
Thanks Haddix and dpcd for the suggestions.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
« Reply #8 on: April 24, 2014 - 02:49:32 PM »
If the rest of the car has some "patina" I would be temped to just clean the engine compartment and leave it.  It will look much better without all the caked on oil/grease....better then a quick spray bomb job too.  Also be prepared for some leaks once everything is clean.  That 30 year old caked on crud can help seal up bad gaskets.  Pay close attention to any factory markings that may be wiped away while cleaning.  A slant E-body retaining some factory markings would be so cool to see.
« Last Edit: April 24, 2014 - 02:52:40 PM by burdar »
« Reply #9 on: April 24, 2014 - 04:34:10 PM »
I bought a kit from POR-15 for my car. There was a degreaser, then an alkaline solution, then brush on paint. It worked well. Obviously I couldn't get to the lower parts of the block, but you can't see down there anyway. Just wear rubber gloves when dealing with POR-15 engine paint or your finger nails will be colored for days.   :o
Offline dpcd67
« Reply #10 on: April 25, 2014 - 11:45:01 AM »
A 6 cylinder E body is a very rare car as everyone removed the 225 for a V8.  No sex appeal though.
1963 Dodge M37 (3)
I ain't done yet.
Offline chongo25
« Reply #11 on: April 26, 2014 - 11:10:48 PM »
That is what I hear. I like the idea of the slant 6 in it because it's seem they are still around. I'll planning on keeping it in it.
