360 SB dual throttle return spring question
Author Topic: 360 SB dual throttle return spring question  (Read 1148 times)
Offline 360FISH
  • BS23H3B567746
« on: April 22, 2014 - 04:57:53 PM »
Hey guys…  The Fish made it through a 1300 mile journey last week with just a leak of tranny fluid (not too bad)…  however in the last 10 miles of the trip I had a stuck throttle.
Turns out the return spring broke.
I found both ends so I have what it looked like (one end was anchored a bolt on the manifold, the other sprang back to sit near the distributor), but I’m thinking of going with a dual spring setup.  I’m running the standard Holley throttle linkage and have an Edelbrock RPM manifold on my 360 SB.
Any easy answers here on the right bracket and spring set to get?
Thanks
Alan
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
Offline cudabob496
Re: 360 SB dual throttle return spring question
« Reply #1 on: April 22, 2014 - 09:42:43 PM »
don't know, but running without a dual return spring could be deadly.
2011 Kawasaki Z1000
« Reply #2 on: April 22, 2014 - 11:15:40 PM »
I often run backwards make or buy a bracket that mounts to the rear carb bolts & run the springs back towards the dist , ALWAYS run 2 springs
Offline cudabob496
« Reply #3 on: April 23, 2014 - 02:20:18 AM »
I've got a double spring pulling towards the firewall, and a single
pulling towards the radiator.  3 should be good enough!
2011 Kawasaki Z1000
Offline CUDA JAS
  • vroooooom!
« Reply #4 on: April 23, 2014 - 08:48:49 AM »
Wow how is the pedal feel on that???
Summit has some nice aftermarket brackets that bolt to the carb base.
He is a pic of what I run...
Although I now run a newer black spring...looks much nicer!!!
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline cudabob496
« Reply #5 on: April 24, 2014 - 10:14:10 PM »
Jason
The double spring was from Summit, but it weakens over time. The third spring is from a hardware store, and it's just
strong enough to return the throttle to off, if the double spring combo broke. So, pedal is not too hard.
2011 Kawasaki Z1000
Offline 360FISH
  • BS23H3B567746
« Reply #6 on: April 25, 2014 - 01:07:20 PM »
I can just see it now...  5 springs!    :bananasmi
Thanks guys...  I'll figure something out...  I'm reading by some that having the springs pull toward the front offsets torquing the "rod"(what ever you call the part the mechanism is rotating on) takes being pulled back by the throttle...
I guess the bottomline is that one spring is a bad idea.   :22yikes:
