Author Topic: Testing lights with dash installed question  (Read 1504 times)
Offline CudamanTom
« on: April 22, 2014 - 07:17:52 PM »
Hey guys.
Got the dash in place and thought I would do some prelim test on some things.  :ylsuper:
First, the steering column nor the engine is installed.
The battery is installed along with headlights wiring.
I've made a good body ground from the neg battery post and have good positive connection to the firewall bundle.
I connect the battery and the glove box light comes on (no door on but switch functions as normal, no problem there).
I turn the head lights on and nothing happens.
I kick in the foot switch for brights and still nothing on the head lights BUT the bright light indicator in the dash comes on.
I check and feel I have the head light harness connected to a good ground on the body.
I even tried new head light bulbs. Nothing.
I did some research and I get confused on what the headlight delay relay does or looks like, especially when I look at the schematics which shows this...
(two green wires to one little barrel lookin plug by the drivers door/kick panel)
So am I missing something? Would this cause my no headlights on issue? What else to look at?
Thanks in advance.
Tom
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Re: Testing lights with dash installed question
« Reply #1 on: April 22, 2014 - 07:22:43 PM »
Maybe a bad headlight switch.
  Do you at least have parking lights?
« Reply #2 on: April 22, 2014 - 07:55:51 PM »
Headlight circuit has a body ground connection to the rad cradle.
Offline CudamanTom
« Reply #3 on: April 22, 2014 - 08:01:06 PM »
That has been made and verified. Thanks for pointing that out though.
Anymore?
Offline CudamanTom
« Reply #4 on: April 22, 2014 - 08:03:16 PM »
Mike, I haven't gotten to the park lights yet.
I haven't check the switch but I could with tilting the dash I think.
It's just funny that the bright light indicator works when I flip the headlight switch to brights.  :clueless:
Offline CudamanTom
« Reply #5 on: April 23, 2014 - 07:07:35 AM »
While I am waiting to test my switch to verify.
Can someone clarify what I asked about on the two green wires connected to a barrel connector and is that for the headlight delay relay as the schematic is showing.
Got to thinking. Maybe the relay is an option I don't have. I guess everything should work without it???  :dunno:
If so, what does the headlight delay relay supposed to do?  :clueless:
« Last Edit: April 23, 2014 - 07:21:59 AM by CudamanTom »
Offline CudamanTom
« Reply #6 on: April 24, 2014 - 07:12:01 AM »
 :2thumbs: :bigsmile: :2thumbs:
Well I guess a delay relay doesn't matter when testing lights in my situation.
Let there be life!!!
I installed the front running light bulbs and with the switch they came on. I thought, what the heck?  :clueless:
So after tinkering with some voltage testing, I saw I was getting voltage from the dash to the firewall. I climbed in the engine bay and took a closer look at the connections at the firewall. Applied pressure to insure a good connection. The connector was not in 100%  :banghead: :stomp: :swear:
I felt like an idiot :pullinghair:
Connected the battery, turned on the light switch and poof... LIGHTS!!!  :ylsuper:
« Reply #7 on: April 24, 2014 - 07:36:37 PM »
Excellent!   :2thumbs:
