Author Topic: window moulding clip pegs  (Read 2146 times)
Offline Sleepychallenger
« on: April 23, 2014 - 09:19:19 AM »
does anyone have pictures of the location for all of these pegs? Im afraid that a couple may be missing from my set up. How do you install new ones? How many should be there front and rear?
Offline FY1Cuda
Re: window moulding clip pegs
« Reply #1 on: April 23, 2014 - 09:48:03 PM »
Don't have the locations handy, but the spots are symmetrical side-to-side, if that is any help.  You're probably going to want to use the screw-on type for  the missing clips.  Many NAPA (or other) auto parts places sell the clips.  Just bring the the peg type with you so you get the same relative size.  If you only need a few, I probably have enough of the screw-on type I can give you.
« Reply #2 on: April 23, 2014 - 10:28:51 PM »
The H & S hotspot Stud welder gun is the ideal choice to weld the stud rivets.
Look over their web page and see their stuff. It's great tool to have.
http://www.hsautoshot.com/Accessories.html
You'll need to order accessories: 1003, 1005, and 1045.
1045 will need to be modified in size so you can get the rivet set perfect into the edge.
There are 12 rivet studs for the front. and here's a picture of the back.
« Reply #3 on: April 23, 2014 - 10:59:14 PM »
thanks guys. Great info.
TC,
Is the H&S welder gun worth getting if I dont plan on doing this again in the next 10 years?
FY1,
I will let you know how many i am missing. I dont think that i am missing many (maybe 3) but Im not really sure.
Thanks again.
« Reply #4 on: April 23, 2014 - 11:03:48 PM »
TC,
FY1,
Thanks again.
No.
I was fortunate.
My friend let me borrow his. I loved it.
Almost didn't want to bring it back to him.  :lol:
I wanted to show how it's actually done.
If you go the screw in type, put a little silicone around the screw where it goes in after the clips are put on.
« Reply #5 on: April 24, 2014 - 12:42:20 AM »
No.
I was fortunate.
Awesome. Thanks for the advice. Im having a hard time doing a mini resto via coorespondance.  :roflsmiley:
« Reply #6 on: April 24, 2014 - 05:20:20 PM »
Do you know how many pegs are around the back
« Reply #7 on: April 24, 2014 - 08:34:25 PM »
I'm taking a guess on when I welded mine on.
14 or 16.
One every 6-8 inches. None on or near the curves.
« Reply #8 on: April 24, 2014 - 10:07:57 PM »
Thanks.
Does anyone have any pictures of the front? I imagine if 12 is the number that it is 6 across the top and 3 on each side, right?
Offline FY1Cuda
« Reply #9 on: April 24, 2014 - 10:25:46 PM »
Sounds right. The two center top ones are only like 6 inches apart to keep the molding connection tight and straight.
old posts that might help:
http://www.cuda-challenger.com/cc/index.php?topic=87281.msg870742;topicseen#msg870742
http://www.papadaveonline.com/imagegalleries/20/index.html
« Last Edit: April 24, 2014 - 10:45:44 PM by FY1Cuda »
« Reply #10 on: April 24, 2014 - 10:38:29 PM »
Thanks.
On Cuda it is 12. I counted mine.
I'll try and take a picture this week-end if you still need.
« Reply #11 on: April 24, 2014 - 10:47:58 PM »
I think that i should be good with the info that you guys have given. Im pretty sure that the cuda and challenger should have the same amount of pegs. The windshield areas are just about the same right?
« Reply #12 on: April 25, 2014 - 10:27:22 AM »
does anyone have a picture of the lower windshield trim installed? he cant figure that out either... :pullinghair:
Offline FY1Cuda
« Reply #13 on: April 25, 2014 - 11:41:31 AM »
The windshields and front moldings are exactly the same for the Cudas and Challengers.  What's not to figure out with the bottom molding?
Here's the only picture I have:
« Reply #14 on: April 25, 2014 - 11:42:40 AM »
I said the same thing. you lay the trim down and put the screws in...Thanks for the picture. Does anyone else have any more?
