Author Topic: window moulding clip pegs  (Read 2145 times)
Offline Sleepychallenger
Re: window moulding clip pegs
« Reply #15 on: April 25, 2014 - 10:06:52 PM »
here is what I have for my window channels. If I only have two clips on each side for the windshield will the trim hold or fly off? what about across the top? As you can see, I have some screw in types, are these different than the peg and clip or do they work the same way? I see I have a lot of little holes that look like they may have had clips at one time...
« Reply #16 on: April 25, 2014 - 11:23:36 PM »
http://www.cuda-challenger.com/cc/index.php?topic=80809.msg810750#msg810750
Found this link. Looks pretty well spelled out for the peg locations huh
Offline FY1Cuda
« Reply #17 on: April 26, 2014 - 07:25:59 PM »
The molding won't fly off with only two clips on  the side, but it probably won't lie down flat either.  I'd put another clip near the bend.
« Reply #18 on: May 09, 2014 - 05:47:09 PM »
What size bit should be used when making the new screw holes?
Offline FY1Cuda
« Reply #19 on: May 09, 2014 - 06:19:35 PM »
Start small, maybe 3/32".  If the screw is too tight, drill it a little larger: 7/64", or larger if need be.  Center punch before you drill so you have the holes exactly where you want them.
