Author Topic: Radiator connumdrum  (Read 4752 times)
Offline HP_Cuda
  • Mopar or No Car!
Radiator connumdrum
« on: April 24, 2014 - 11:51:25 AM »
 :wave:Well after fighting with the installation of my Champion radiator I finally got it in to then find out how close the clutch fan is from the radiator.
How much room is there supposed to be between the clutch and the radiator? I'd hate to bury the clutch into the new rad.
 :bricks1:
« Last Edit: April 25, 2014 - 03:16:24 PM by HP_Cuda »
Offline CudamanTom
Re: Radiator connumdrum
« Reply #1 on: April 24, 2014 - 12:09:18 PM »
Wow, that's close.
Sorry I don't have the answer but I think it's a good call to verify.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline cordodge
« Reply #2 on: April 24, 2014 - 12:20:11 PM »
looks like you will have to do away with the clutch and maybe run a 7 blade solid fan?
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline crocha617
« Reply #3 on: April 24, 2014 - 01:07:06 PM »
Was it a big fight to fit in there? Please explain I was thinking of ordering one for a 440 26" support with auto. doesn't it bolt right in? How about the fan shroud mounting?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: April 24, 2014 - 02:06:20 PM »
Guess I have to give away all my secrets now.  :bigsmile:
The Champion I got was a 4 row radiator based on the HP I should be producing. This may be adding to the thickness of my problem. I ordered the stock clutch fan for a 440 and I believe since the stock radiator is thinner this is not a problem.
The radiator wasn't that bad to lower into place but the pain in the a**  :bricks1: was that I had to modify the upper left mounting point (driver side top). Basically I had to enlarge the hole to even get the bolt to start. It's a pretty tight fit as far as tightening down the bolts so I'd rather not pull it again. I think I can pull the clutch off but then again the nub from the water pump might prevent me. Add to this I had to use spacers to get proper belt alignment. Ughhh!
Onto the shroud, it does fit but you need to basically pinch the plastic from each side to get the holes to line up. You cannot just lay the shroud on top of the radiator and have it line up. It's doable but it will be a slight pain.
After writing all this I think I may have already found that I have to pull the radiator again! Oh the humanity!
 :faint:
Offline Strawdawg
    • Vortex Buicks
« Reply #5 on: April 24, 2014 - 05:31:47 PM »
Fan should be 3/4"-1 1/4"  from radiator as I recall
Or the fan blade should be about 75% into the shroud
Steve
« Last Edit: April 24, 2014 - 05:41:39 PM by Strawdawg »
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: April 24, 2014 - 06:10:36 PM »
I am thinking of pulling the radiator and having the clutchfan decked to get more room.
Good thing I have a friend with a machine shop.
« Last Edit: April 25, 2014 - 01:38:50 PM by HP_Cuda »
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: April 24, 2014 - 09:42:24 PM »
I took a look at my other Cuda and found that it was exactly 1" away from the radiator and it looks about right.
So for more good news, I pulled the clutch fan without having to pull the radiator and no damage was done. I found out that the clutch fan I have now is 3.5" tall so I should go for something like 3" tall or just short of that to get my desired distance. I believe I have about 1/2" now.
Ordering a new hayden clutch and I think this one will work for good!
Offline ChallengerHK
« Reply #8 on: April 25, 2014 - 02:57:50 AM »
Could you cut the spacer down to bring you back to the correct clearance?
- Han Solo, Star Wars
Offline Strawdawg
    • Vortex Buicks
« Reply #9 on: April 25, 2014 - 08:50:48 AM »
They make spacers in increments of half inches
Steve
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: April 25, 2014 - 11:13:42 AM »
The spacers are used to push the pulley out to make the belt align better.
So that wouldn't work. The only way is to find a shorter fan clutch.
Offline Strawdawg
    • Vortex Buicks
« Reply #11 on: April 25, 2014 - 11:27:07 AM »
Defintion problem--Spacer I was referring to mounts on the pilot sticking out of the pump flange and positions the fan with relation to the radiator :)
Also, flex fans don't go on clutchs...on fixed blade factory style fans are used with a clutch :)
Having said all that, I think Chryco as posted the number of a Jaguar fan clutch that is not as deep as the ones we normally use.  You might ask him?  :)
« Last Edit: April 25, 2014 - 12:08:22 PM by Strawdawg »
Offline HP_Cuda
  • Mopar or No Car!
« Reply #12 on: April 25, 2014 - 01:36:02 PM »
I never said flex fan so  :clueless:
The problem is specifically from the pulley face to the end of the fan clutch. You could try and deck the surface of the clutch fan mount point but as it's only a 1/4 inch thick it wont help much with my problem
If you research haydens you can find one that works.
Good luck!
Offline Strawdawg
    • Vortex Buicks
« Reply #13 on: April 25, 2014 - 02:05:26 PM »
Well after fighting with the installation of my Champion radiator I finally got it in to then find out how close the flex fan is from the radiator.
 :bricks1:
Here?  :)
Offline HP_Cuda
  • Mopar or No Car!
« Reply #14 on: April 25, 2014 - 03:18:57 PM »
As you can see from the pic its not a flexfan
C L U T C H
