Guess I have to give away all my secrets now.
The Champion I got was a 4 row radiator based on the HP I should be producing. This may be adding to the thickness of my problem. I ordered the stock clutch fan for a 440 and I believe since the stock radiator is thinner this is not a problem.
The radiator wasn't that bad to lower into place but the pain in the a**
was that I had to modify the upper left mounting point (driver side top). Basically I had to enlarge the hole to even get the bolt to start. It's a pretty tight fit as far as tightening down the bolts so I'd rather not pull it again. I think I can pull the clutch off but then again the nub from the water pump might prevent me. Add to this I had to use spacers to get proper belt alignment. Ughhh!
Onto the shroud, it does fit but you need to basically pinch the plastic from each side to get the holes to line up. You cannot just lay the shroud on top of the radiator and have it line up. It's doable but it will be a slight pain.
After writing all this I think I may have already found that I have to pull the radiator again! Oh the humanity!
