Author Topic: Clutch adjuster rod too short  (Read 1053 times)
Offline Chlngrcrzy
« on: April 25, 2014 - 05:23:30 PM »
Have a 73 big block with 4 speed. Used to be a 318  setup.  Used the same z bar and clutch fork. Have new clutch and z bar rebuild kits already installed, but i don't have enough length on the adjuster rod to get my pedal back up to the top. I have about 2.5" to 3" of free play still.  Could my fork be bent or can i just get another adjuster rod that is longer? My adjuster rod has about 3.5" of thread. Another thought i had was maybe i have the z bar backwards.
But i don't think so, i have looked at countless pictures and my manual all show the same thing.
 :clueless:
Offline Chlngrcrzy
Re: Clutch adjuster rod too short
« Reply #1 on: April 25, 2014 - 06:04:10 PM »
Update. i adjusted as far out as i could with out the rod coming through the fork bushing. i have a little over 1.5" of free play.
Offline Chlngrcrzy
« Reply #3 on: April 25, 2014 - 10:41:01 PM »
I just adjusted mine further until i had a little over 1/2 of play. Now my adjuster rod is barely in the bushing. Everything is great, except i don't trust that rod to stay in it. like to be able to put a nut on the backside just to keep it on in case the spring or the clip break.
Thanks for the Tip. I will get me one ordered up.
