Author Topic: Right stuff is the wrong stuff  (Read 922 times)
Offline Duff
« on: April 25, 2014 - 08:27:42 PM »
I've got a right stuff disc brake system that has floating calipers that rattle and clunk like hell.  Can anyone recommend a solid mounted caliper system that would bolt to my existing spindles?
Offline bc3j
Re: Right stuff is the wrong stuff
« Reply #1 on: May 08, 2014 - 12:39:31 PM »
Are you referring to slider calipers?  I use the slider type from a '79 Diplomat. The outer pad sometimes needs to have the tabs hammered down so they just "snap" into the caliper. I also put a very thin coating of the high heat brake grease on the track the caliper slides on. I also don't use those rubber bands. No noise or anything for me. The brakes are quiet.
Offline V02Barracuda
« Reply #2 on: May 09, 2014 - 12:45:09 PM »
I agree with bc3j.  The outer pad needs to fit snug.  I also spray on the red "disc brake quiet".  No noise at all.
Offline 72cudamaan
« Reply #3 on: May 09, 2014 - 07:52:53 PM »
Are the caliper mounts new? If not, they may be worn. Quite a common problem.
If I cant fix it, it's broke
Andy  (phukker whither)
