Author Topic: Can glazing putty go over high build primer?  (Read 730 times)
Offline 74BlueFish
« on: April 25, 2014 - 10:07:53 PM »
I got the body epoxy primed and then high build primer sprayed.  I'm block sanding with 400 grit paper after spraying guide coat.
I have some low spots of about .003 I'm guessing.  Should I apply ultra smooth glazing putty (evercoat is what I have) or spray another coat of high build? I think it might be 2 coats to get it to be smooth.
Also have 1 or 2 places that are too high.  Should I tap it with a hammer to lower them?
I sprayed 3 coats of the high build on the first coat spray .  Used 1/2 gallon non the body, less hood and trunk lid.
Can I apply the evercoat over the low spots that have the high built and the guide coat showing?
Thanks,
Dan
Dan
Offline Haddixj
Re: Can glazing putty go over high build primer?
« Reply #1 on: April 25, 2014 - 10:15:46 PM »
The class I took thorough the local community college said that its ok and that HE has used it on top of base coats if just repairing a small area so he didn't break through the paint and possibly cause a hot spot behind the repair
Offline 74BlueFish
« Reply #2 on: April 27, 2014 - 08:00:36 AM »
Ok,   Thanks for the advice, will try that next week.   Getting ready for an aerobatic contest this week.
Dan
Dan
