Author Topic: piston / cylinder question  (Read 774 times)
Offline Loa
« on: April 26, 2014 - 08:35:16 AM »
Hello,
I've removed the heads from my 340 (to machine the valves) and discovered that the piston heads and cylinders were quite blackened (like the bottom of the heads).
Is that normal? Can I or should I clean them? if so, with what?
Thanks
Re: piston / cylinder question
« Reply #1 on: April 26, 2014 - 09:42:27 AM »
It's normal. Just carbon build up. Might be running a bit rich?  What do the plugs look like?
Offline dpcd67
« Reply #2 on: April 26, 2014 - 11:04:57 AM »
What he said. Your machine shop will clean the heads before they work on them.
1963 Dodge M37 (3)
1967 Dodge WM300 (2)
1971 Plymouth Duster
Bought new in '71; I wanted the Challenger but they were $2850; too much $ so I got the 318, 3 speed on the floor, Twister Duster for $2100.
1973 Plymouth Barracuda
I ain't done yet.
Offline Loa
« Reply #3 on: April 26, 2014 - 01:30:36 PM »
The plugs are black and will be changed.
Since I only saw the pistons because we're changing the cam, lifters, redoing the valves and rebuilding the carb, I don't think I can really adjust anything right now...  :-)
I know my carb is too big, a Holley 780. It was already on the engine when I bought it last summer, and I'm planning to change it when I find the cash.
« Last Edit: April 26, 2014 - 01:34:39 PM by Loa »
« Reply #4 on: April 26, 2014 - 02:56:13 PM »
set properly a 780 is really not overly large for a 340 , the factory used 800 cfm thermoquads
Offline Loa
« Reply #5 on: April 26, 2014 - 03:27:03 PM »
Nice, and good to know!
Any tips on how I could set it up? The jets are 70 right now. Should I change them?
Loa
Offline Strawdawg
    • Vortex Buicks
« Reply #6 on: April 26, 2014 - 03:50:39 PM »
Loa
they are probably close...looking at plug color after a wide open throttle run is the tried and proven method.  today, if we buy one, we can use a wide band O2 sensor for tuning a/f but there will not be a significant change in the hands of an experienced tuner that looked at the plugs...
« Reply #7 on: April 26, 2014 - 07:30:10 PM »
in the Archive section there is a basic Holley tuning guide , you need to work through that in order , or every change will affect another circuit , work through that I will can help if you have issues
Offline Loa
« Reply #8 on: April 26, 2014 - 07:32:26 PM »
Found it, will read and apply!
Wow! That is a lot of steps! Glad to have found the guide.
Loa
« Last Edit: April 26, 2014 - 07:58:31 PM by Loa »
