Low Compression
Author Topic: Low Compression  (Read 6735 times)
Re: Low Compression
« Reply #30 on: May 02, 2014 - 10:47:31 PM »
sounds to me like the heads & seats are going south on all cylinders just 1 is worse then the others , I doubt the compression will rise in any of the other cylinders with oil either , , time for head work
Offline Strawdawg
    • Vortex Buicks
Re: Low Compression
« Reply #31 on: May 02, 2014 - 10:53:44 PM »
yep...if the rings were that bad, the car would be smoking badly and showing a lot of blow by out the valve covers
Offline cudabob496
Re: Low Compression
« Reply #32 on: May 03, 2014 - 01:34:15 AM »
except for #8, looks like the average cyclinder pressure is about 140 psi, which may
be perfectly normal for an older engine.  Assuming it started out new at 180 psi, even
with perfect head work, may only get pressures to 160 psi, simply because of the
older rings and cylinder wall wear and scratches, which cause a loss of cylinder pressure,
and which Engine Restorer is suppose to help fix.
« Last Edit: May 03, 2014 - 01:37:54 AM by cudabob496 »
2011 Kawasaki Z1000
Offline cudabob496
Re: Low Compression
« Reply #33 on: May 03, 2014 - 03:10:44 AM »
checking plug color on #8 could also be a way to tell
if loss of pressure is due to poor ring seal. Darker plug
means burning oil past rings.
« Last Edit: May 03, 2014 - 05:19:16 AM by cudabob496 »
2011 Kawasaki Z1000
Offline cwestra
Re: Low Compression
« Reply #34 on: May 03, 2014 - 09:25:48 AM »
Here's a little more history on the engine.  I rebuilt it completely around 4 or 5 years ago with the following main things done.
Bored .030" over.
9.5:1 Keith Black cast pistons
Lunati 60402 cam (262°/268° advertised duration, .475"/.494" lift at rocker, 112° LSA)
Head work including hardened seats and valve replacement where needed.
There has been less than 10,000 miles put on the car since the rebuild, most highway or around town but some aggressive driving mixed in.
Compression check on engine in May 2010 was as follows;
#1 -  150 psi          #2 -  135 psi
#3 -  150 psi          #4 -  142 psi
#5 -  150 psi          #6 -  142 psi
#7 -  145 psi          #8 -  153 psi
Except for cyl #2, all seem close.  Including #2 they are within around 10% of each other (just about).  Now I don't know what the  correct numbers should be with this engine combination (pistons & cam mainly), but I'm not sure if it would be up in the 180 psi range.  If I'm wrong, which certainly could be the case, then I'm open to feedback.  But they were reasonably consistent then and I felt with the 112° LSA on the cam that I might be losing some because of that.  Please, though, chime in with your thoughts.  If something doesn't look right I want to correct it.
Also, I have attached a picture of the plugs when I pulled them out just before taking the latest compression readings.
I'm not sure what I'll ultimately find the problem to be, but it seems too early after the rebuild to be experiencing this, regardless.  I know I have fought the 6 bbl. carb set up for quite a while and could have been running lean during that time.  Not sure if that could possibly explain burnt exhaust valves so soon though.
« Last Edit: May 03, 2014 - 09:28:07 AM by cwestra »
Corey - in Northern Indiana
Offline 72cudamaan
Re: Low Compression
« Reply #35 on: May 03, 2014 - 09:54:16 AM »
Running lean could definitely lead to burnt valves. It could also lead to melted pistons right at the ring lands, which
could explain why no compression increase with oil. How is the rocker adjustment? Just a thought, though it sounds
to me like taking the heads off and doing a thorough inspection is the best thing for you to do before any other
damage can be created. By the way, is the lean condition fixed?
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 72cudamaan
Re: Low Compression
« Reply #36 on: May 03, 2014 - 09:55:39 AM »
Northern Indiana isn't too far away. Maybe time for a tear down party?
Offline cwestra
Re: Low Compression
« Reply #37 on: May 03, 2014 - 10:07:08 AM »
I checked the rocker adjustment on #8 and it was fine.  The spec says adjust to 0 clearance and add another 1.5 turns.  Rockers on #8 were closer to .75 turns.
I did install an AFR meter last year and made some minor adjustments to improve the mixture situation, but I suppose that doesn't necessarily mean 1 or 2 cylinders aren't, for some reason, still running lean.  Attached are a couple of charts showing what I am getting.  At a cruise I am still running a little lean but thought that was normal.
I will have a good look at pistons once heads are off.  Thanks
Offline cudabob496
Re: Low Compression
« Reply #38 on: May 03, 2014 - 11:46:31 AM »
were cylinders bored/honed with a torque plate? If not,
can get distortion of cylinder wall diameter near top of cylinder.
interesting, #8 was your highest reading in 2010.
was pressure check with warm engine in 2010?
« Last Edit: May 03, 2014 - 11:52:03 AM by cudabob496 »
2011 Kawasaki Z1000
Offline cwestra
Re: Low Compression
« Reply #39 on: May 03, 2014 - 01:51:59 PM »
Might be.
Offline cwestra
Re: Low Compression
« Reply #40 on: May 03, 2014 - 05:24:10 PM »
I just finished doing a leak test.  Below are my results.
#1 -  94%          #2 -  89%
#3 -  95%          #4 -  90%
#5 -  95%          #6 -  87%
#7 -  93%          #8 -  28%
Number 8 I can clearly hear hissing from the tail pipe and not on any of the others.  On all, I can clearly hear hissing from the inside of the block (rings).  This is true even for the cylinders reading 95%.  My concern is with the cylinders showing 87% - 90%, as they appear to be on the border (right bank).  How much power am I losing with these borderline cylinders?  Is it worth putting rings in?  Also, why would I be experiencing issues only with one bank?
Offline Strawdawg
    • Vortex Buicks
Re: Low Compression
« Reply #41 on: May 03, 2014 - 05:37:29 PM »
Looks like Neil hit it on the head.   In the greater scheme of things,  87% is not all that bad. Might be a little leak in the passenger side but I would guess valves.    Time to work the heads or swap another set on.
Steve
Offline cwestra
Re: Low Compression
« Reply #42 on: May 03, 2014 - 08:01:30 PM »
Steve
As usual.
Offline cwestra
Re: Low Compression
« Reply #43 on: May 03, 2014 - 10:38:34 PM »
Here's a picture of the burned valve.  You can see the light from behind shinning through.  Not much but enough.  Also, I've include a picture of all the valves on the right side head.  Is the color of the exhaust valves indicating an extreme lean condition?
The last picture is of the exhaust manifold.  For some reason one of the middle ports is dark sooty black and the other is almost a white color.  Has anyone seen anything like this before.  The other manifold is the same way.  May not be linked to my problem but just seems odd.
Re: Low Compression
« Reply #44 on: May 03, 2014 - 10:45:59 PM »
Well at least you have found the problem , too lean , probably , excessive heat one the exhaust valves , weird on the exhaust manifold though , most dual plane intakes feed both center ports from the same side of the carb , what intake are you using ?
