Author Topic: Glove Box Light Bulb?  (Read 977 times)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« on: April 27, 2014 - 10:47:45 PM »
Can someone tell me the correct bulb used in the glove box light socket?  Is it an 1891 or 1893 or other?  Thanks.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline CudamanTom
Re: Glove Box Light Bulb?
« Reply #1 on: April 28, 2014 - 07:15:28 AM »
It's 1445.
At least that what was in mine and replaced it with the same. Works perfectly.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline anlauto
« Reply #2 on: April 28, 2014 - 07:19:27 AM »
Glove compartment is a #1891....however several bulbs will work as mentioned :2cents:
Offline CudamanTom
« Reply #3 on: April 28, 2014 - 08:13:11 AM »
Then RockAuto needs to change there number for them online.
GE 1445 (1445/BP2) Glove Box Light Bulb $ 0.44 $ 0.00
Offline anlauto
« Reply #4 on: April 28, 2014 - 09:07:31 AM »
The #1445 would just be a subsitute bulb, nothing wrong with that. The factory service manual and owners manual call for the #1891 though. :2cents:
Offline JayBee
« Reply #5 on: April 28, 2014 - 09:20:09 AM »
Just checked my factory owners manual - #1891
John
1970 Barracuda convertible
2014 Toyota Avalon
