I replaced the torque converter and oilfilter, everything else is the same as it was.
Before I put the new converter in, I filled it with Dexron3 automatic oil to the point where it came back out when I put it on the side.
Anyway, after I put it all back together I started it up and it sort of didn't want to react like it did with the old converter.
With the old converter I had to apply the breaks when I put it in Drive because it wanted to go right away.
Now it's like it wants alot of rpm to even react.
It felt sort of like driving with a bad clutch. Especially uphill it wants alot of rpm.
Is there a trick to this that I'm missing? My first thought was the link between the shifter and the trans, that maybe if that isn't set 100% it don't act right..?
