I know this has been addressed before but all the answers were too hard for me. I made a test stand to break in my 340 cam. What I need is the absolute minimum wiring directions to make this thing run for 20 minutes. I don't need any permanent solutions as this will be a one time thing. I plan to use mechanical temp and oil pressure gauges. I will hot jump the starter. What I need is how to hook up the wires from the battery to the OEM type electronic dist (which has two wires), to coil and tach (12 volt tach); it is a 73 electronic ignition. One question is do I need the resistor in the loop? I won't use an alternator.
Keep it basic and simple please. thanks.
