Author Topic: Radio Dash Bezel?  (Read 759 times)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
Radio Dash Bezel?
« on: May 02, 2014 - 02:05:11 PM »
Saved this photo a while back from PCG website.  Does anyone know if the radio dash bezel is supposed to have the small foam square attached to it (see red arrow)?  If so, what's its purpose, and what size is it?  Thanks.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Re: Radio Dash Bezel?
« Reply #1 on: May 02, 2014 - 02:15:55 PM »
Mine had a piece of foam there.  It was probably 1/8" thick and not very big.  It's just to keep down any rattles since the bezel is fairly close to touching the back side of the dash pad.
Offline anlauto
« Reply #2 on: May 02, 2014 - 03:34:30 PM »
Yes :iagree: The heater control bezel has one too but it's on the opposite side for some reason towards the outside of the car.
