Author Topic: Another Dash Question  (Read 5079 times)
Offline CudamanTom
Re: Another Dash Question
« Reply #15 on: May 05, 2014 - 09:49:16 PM »
thanks for the pics filmsurgeon but i really mean the foam between the pad and the frame.
The dash pad should have the foam already. You will have to strip the frame of any foam.
Now if your talking dash "cap" then all the foam needs to remain intact.
Anybody correct me if I'm mistaken.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline elmoska
« Reply #16 on: May 18, 2014 - 05:20:53 PM »
I  was talking about this
1974 challenger on its way..
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #17 on: May 18, 2014 - 06:22:21 PM »
That's what I posted photos of.  I don't believe mine was REM brand.  Different manufactures make the under-dash insulation differently.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline filmsurgeon
« Reply #18 on: May 18, 2014 - 06:32:03 PM »
FWIW - Here's an ebay listing for the insulation showing a photo of the uninstalled insulation, and a photo showing it installed.
http://www.ebay.com/itm/70-74-Cuda-Challenger-Under-Dash-Insulation-/400711809844
Offline elmoska
« Reply #19 on: May 18, 2014 - 07:17:30 PM »
it was sold to me like it was a insulation between the pad and the frame ... dohhh
 :newbie:
Offline elmoska
« Reply #20 on: July 06, 2014 - 08:23:42 AM »
after all the dash is assembled , do you have to put some wiring before installing it in the car ?
what about the e-brake cable and the pedal assembly.
i guess you have to install the heater box first because of the defrost vent for the windshield.
i dont wanna install my dash and figure out that i had to installer something first and take it out again.
thx
Offline CudamanTom
« Reply #21 on: July 06, 2014 - 10:24:28 AM »
What wiring are you talkin about?
As for the peddles, it would be a lot easier to install them first as you have more room. Same with the e-brake although I installed mine after the dash was installed.
I also installed my heater box first. The defrost ducts MUST be installed first.
Offline elmoska
« Reply #22 on: July 06, 2014 - 10:42:56 AM »
is there only the junction block that goes trew the firewall and all the other wiring is already attached to the dash when you install it.
Offline CudamanTom
« Reply #23 on: July 06, 2014 - 10:51:38 AM »
Yes.
Kinda.
There will be other wiring to attach once the dash is installed. Steering column, electric windows (if optioned), speakers, ect....
Mainly the dash harness for the gauges and such.
« Last Edit: July 06, 2014 - 10:55:13 AM by CudamanTom »
Offline roadman5312
« Reply #24 on: July 06, 2014 - 10:58:27 AM »
Good info  :popcorn:
Offline elmoska
« Reply #25 on: July 10, 2014 - 08:48:44 PM »
One more thing, if you haven't thought about it.
Make sure the heater-A/C control cables are mounted behind the heater-A/C control panel before installing the dash. Those are a bear to get to after dash is installed.
Also, if the heater-A/C box or fresh air vent on drivers side are removed, install those first.
i'm not sure to understand but .. you say to installe the cable on the control panel before installing the dash?
i dont see how i could install the cable on the climate unit after installing the dash because its behind the defroster duct anyway.
on this picture it looks like the cable are all installed on the unit
Offline elmoska
« Reply #26 on: July 13, 2014 - 01:59:45 PM »
 :clueless:
 :popcorn:
Offline Surfmichaels
« Reply #27 on: July 13, 2014 - 02:31:43 PM »
Maybe its that There are some bolts/screws that align the wire as it connects to the heater box itself, it's on the upper rear for least one cable and would be a bear to get to once the dash is installed.  It's the one in the far right in the pic above.
Offline CudamanTom
« Reply #28 on: July 13, 2014 - 06:57:30 PM »
Yep, it's the one on the climate control. It's much easier to install/attach to the dash, then install the dash.
The one for the heater box isn't that bad because you can access that from the glovebox with the insert removed.
Offline elmoska
« Reply #29 on: July 22, 2014 - 09:30:09 PM »
so the def cable should be cliped on the climate control before installer the dash.
sorry i'm a bit slow because of my English, i dont wanna make mystake and take the dash on and off.
