Author Topic: 73, 340 compression question  (Read 6769 times)
Offline crash340
« on: May 02, 2014 - 06:43:33 PM »
So, 340's built mid 72 and beyond (the blue motors), are low compression motors, small valves etc, do the obtain the low compression by using open chamber headed?, if I swap heads to earlier 340 big valve heads will I automatically get better compression slightly ( or by going to say Indy heads). I know I may not get the 10.5 compression of a 340 due to pjston difference but a little gain would be nice.
Greg
73 Cuda
Brisbane, Australia
Offline cudabob496
Re: 73, 340 compression question
« Reply #1 on: May 02, 2014 - 07:14:13 PM »
you need to know things like stroke, depth of pistons below deck, and head combustion chamber
volume, to calculate your Compression Ratio.
http://www.csgnetwork.com/compcalc.html
2011 Kawasaki Z1000
Offline crash340
« Reply #2 on: May 02, 2014 - 07:39:02 PM »
Thanks Cudabob, yep understand that's how to calculate c/r, just want to know if that's how the later 340's got there lower c/r by use of open chambers in the heads, broadly speaking.
Greg
73 Cuda
Brisbane, Australia
Offline cudabob496
« Reply #3 on: May 02, 2014 - 09:03:08 PM »
that's usually how they did it, but not 100%
2011 Kawasaki Z1000
Offline 72cudamaan
« Reply #4 on: May 02, 2014 - 09:44:26 PM »
Older 340's had a dome piston to raise the compression
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #5 on: May 02, 2014 - 09:45:41 PM »
Basically no , the 340/360 heads used approx. the same size combustion chamber in all years , it was the piston that changed the compression , the early 340 piston was actually slightly above the deck
Offline cudabob496
« Reply #6 on: May 02, 2014 - 10:36:46 PM »
OK, learned something new. Maybe I was thinking big blocks? Or did big blocks
change piston design too?
2011 Kawasaki Z1000
Offline crash340
« Reply #7 on: May 02, 2014 - 10:39:33 PM »
Thanks all, was just thinking I could maybe buy my aluminum heads for the 408 build and throw them on my late 72 blue 340 in the interim and end up with slightly raised c/r.
Greg
73 Cuda
Brisbane, Australia
« Reply #8 on: May 02, 2014 - 10:45:25 PM »
you would actually lose , the Alum head will lower compression heat by 1 point so unless the heads increase the compression by more then 1 point you are losing that way too .
Big blocks had 2 series of heads , small closed chamber 78 cc & larger open chamber heads 88cc
 but they also used different pistons , std 440 used approx. 9:1 pistons , Magnums had taller pistons with valve reliefs putting them closer to 10:1 , Later years after 72 use even shorter pistons with effectively 7.8:1 compression
Offline crash340
« Reply #9 on: May 02, 2014 - 11:40:58 PM »
Ahhh the font of knowledge, thanks CP.
Greg
73 Cuda
Brisbane, Australia
Offline cudabob496
« Reply #10 on: May 03, 2014 - 12:47:33 AM »
you can compensate somewhat, for cylinder pressure, when switching to alum, by running a hotter thermostat.
I felt a power increase when going from 170 to 200 degrees coolant temp.
2011 Kawasaki Z1000
Offline dpcd67
« Reply #11 on: May 03, 2014 - 11:07:49 AM »
I am with you; I have a 73 340 I just built. I kept the 360 heads that came on it, but the lower compression is due to the fact that the pistons are below the deck by at least .1 inch. (And as mentioned, old 340s were zero or above the deck. So, I got some pistons that are zero deck clearance and the compression is supposed to be about 9.5 to 1.  If you are interested, I will look up which pistons I got; I think they were sealed power forged. That was last summer and I forgot.
1963 Dodge M37 (3)
1967 Dodge WM300 (2)
1971 Plymouth Duster
Bought new in '71; I wanted the Challenger but they were $2850; too much $ so I got the 318, 3 speed on the floor, Twister Duster for $2100.
1973 Plymouth Barracuda
I ain't done yet.
Offline crash340
« Reply #12 on: May 03, 2014 - 05:44:32 PM »
Thanks dpcd, I appreciate the offer, no need, it was just a random thought passing through my ever speeding brain to do a simple head swap for now to gain me some cr and larger valves, the plan is to pull the engine and store it as its a numbers matching item, i'm going to pick up a 360 block, stoke it, head it and more than likely inject it. until then though, I have a six pack I was going to just throw on it for fun for a while and figured if I have the intake off and the exhaust off, a few bolts and a set of heads would be a breeze, changing out pistons etc at this stage is not on the white board.
Greg
Greg
73 Cuda
Brisbane, Australia
Offline mrbill426
    • All Around Mopars
« Reply #13 on: May 03, 2014 - 07:54:05 PM »
On that note, if one were to install earlier ("taller") 340 pistons in this later block, how much valve lift/duration would be safe without worrying about piston to valve clearance?  Assuming a hydraulic cam were used, and very little more than a one-time resurface were done to the heads.  What were they, 10:1 pistons?
 :working:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline cudabob496
« Reply #14 on: May 03, 2014 - 07:59:18 PM »
 :working:
Generally I think you need at least .1 inches clearance piston to valve clearance. That's what I was told when changing cams on my 440. But taking some measurements initially is the right thing to do.
« Last Edit: May 03, 2014 - 08:00:49 PM by cudabob496 »
2011 Kawasaki Z1000
