Author Topic: Cooler Coolant means more Engine Wear!  (Read 589 times)
Offline cudabob496
« on: May 03, 2014 - 05:15:49 AM »
Below says engine wear doubles if running 160 degree T/S, verses 185 degree T/S.
http://www.carnut.com/ramblin/cool3.html
« Last Edit: May 03, 2014 - 06:40:14 AM by cudabob496 »
2011 Kawasaki Z1000
Re: Cooler Coolant means more Engine Wear!
« Reply #1 on: May 03, 2014 - 06:48:46 AM »
I've always believed that the people who put in the lower * t-stats were doing it just for the few extra ponies for max horsepower and lower 1/4 mile times
and not concerned about the extra wear. I run a 195* t-stat. Pretty sure the 440 was designed to run at that temp.
Offline cudabob496
« Reply #2 on: May 03, 2014 - 11:42:23 AM »
I read the goal should be a cool air/gas charge into engine, with hot heads/coolant temp.
NASCAR engines run at 215 degrees
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: May 03, 2014 - 02:16:26 PM »
190 degrees has been proven to be the best temperature for fuel atomization for a normal engine.
