Author Topic: 340 6-barrel Adjustable Rocker Spec  (Read 496 times)
Offline cwestra
« on: May 05, 2014 - 08:45:16 PM »
Getting ready to re-install the rockers on my T/A engine.  The spec for adjusting the rockers says tighten to zero clearance then tighten another 1.5 turns.  This seems too tight, as they were closer to .75 turns when I disassembled them a few days ago and I had no noise issues with them like that.  Does anyone know if the 1.5 turn spec is accurate?
Corey - in Northern Indiana
Offline cudabob496
2011 Kawasaki Z1000
Re: 340 6-barrel Adjustable Rocker Spec
« Reply #2 on: May 05, 2014 - 09:34:12 PM »
If it is happy at .75 turns it is less likely to pump up & hold a valve open , I have preferred to be on the less preload side as long as the pushrods do not drop out .
Offline cwestra
« Reply #3 on: May 06, 2014 - 07:48:33 AM »
Thanks, guys.
