Author Topic: 340 six pack idle stop solenoid adjustment arm  (Read 779 times)
Offline joes68340s
« on: May 06, 2014 - 05:46:35 PM »
Well I got all excited about getting a solenoid and then noticed That the arm on the linkage that you set the solenoid with is broken off. Common problem I guess. Is there a fix or anyone make a linkage part.
Re: 340 six pack idle stop solenoid adjustment arm
« Reply #1 on: May 06, 2014 - 09:49:23 PM »
Well you can weld a lever onto the arm or you would need a new throttle shaft or base plate
« Reply #2 on: May 06, 2014 - 09:59:23 PM »
Scott at Harms auto is very good with these.
Contact him on his recommendations.
He might even have parts for these.
Offline joes68340s
« Reply #3 on: May 06, 2014 - 10:18:02 PM »
Thanks I will look into that. Whats with all the brakes Gorilla hands or fragile part.
