Author Topic: This just in....ALL DONE!!!  (Read 61882 times)
Offline anlauto
Re: This just in....
« Reply #120 on: May 29, 2014 - 04:44:17 PM »
7 clips slide into the metal retainers that are fastened to the door panel itself :2cents:
Offline anlauto
« Reply #121 on: May 30, 2014 - 03:35:56 PM »
Friday 05/30/14  4 hours === 52 hours Total
Just as I thought.....Working with the aftermarket stuff is certainly more time consuming. For the Hydramax Clutch Kit I had to remove the "nub" on the clutch pedal and drill a hole for a heim joint....No way I could have done this with the dash in place. Then in the engine compartment I want to make it look like a "stock" mod, so I retain the proper standard brake firewall plate and wire holders/nuts etc...I made an "L" bracket to mount the extra reservoir..., tried to keep everything clean looking. Also installed the new proportioning valve and started on some brake lines. Looks like I'll need to make my own lines for the master cylinder...
« Last Edit: May 30, 2014 - 06:01:33 PM by anlauto »
Offline turbo224
« Reply #122 on: May 30, 2014 - 04:15:19 PM »
Looks like a clean install!
~Tyler Larsen~Salt Lake City
-1971 Plymouth Cuda 440-6pk Tribute
-1992 Dodge Daytona IROC R/T
« Reply #123 on: May 30, 2014 - 05:41:21 PM »
Looks good, I mounted my p valve there too. (same valve as well)
 :poopoke:   Hey what's a " hymn joint"  Does it sing inspirational music when pressed?  Or maybe it's a type of "funny" cigarette that Jamaicans smoke in there place of worship?   :roflsmiley:
Sorry couldn't resist :crazy:  ..... I know what you meant!  :grinyes:
Offline anlauto
« Reply #124 on: May 30, 2014 - 06:20:48 PM »
Funny guy...I blame my "spell checker"... :icon16:
I believe you're the one that told me about removing the brake light switch....on the last one I installed.  :worshippy
I just found out they sell precut lengths of stainless line with the fittings all ready on them, so I think I'm just going to go that route....easier then trying to flare stainless lines :pullinghair:
« Reply #125 on: May 30, 2014 - 06:46:31 PM »
Yes I buy them thru my local Allstar Performance distributor. :2thumbs:
 http://www.allstarperformance.com/
http://www.allstarperformance.com/product.htm?prod=997
I found I had to tighten them and loosen them a few times to get them to seat and not leak. Stainless is tougher than steel
Offline anlauto
« Reply #126 on: May 30, 2014 - 07:00:32 PM »
Goes without saying :2thumbs: :cheers:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #127 on: May 31, 2014 - 01:15:01 PM »
But flaring is so much fun!!!!
Don't ask..... :woohoo:
Offline anlauto
« Reply #128 on: June 02, 2014 - 05:10:15 PM »
Monday 06/02/14  5 hours === 57 hours Total
Today I was able to finish up and the brake lines and the instalation of the main power wire for the stereo....I wanted to keep it out of sight as much as I could...I'm not a fan of that crap.
Got the car off the cart and installed the rear end....Ran out of time to finish the rear end install....it got too hot in the garage and the pool was calling my name :D
Offline anlauto
« Reply #129 on: June 02, 2014 - 05:32:33 PM »
Today was another example of things done "out-of-order"  in my opinion. Fuel lines. You should plan to run all the fuel lines first before the rear axle assembly goes it. It's much easier that way. :2cents:
In this case, I have to mount the external electric fuel pump/filters for the fuel injection. Still not sure where I can mount it, I wanted the rear end in place so I can see what my options are. Also right now the entire fuel system is at the engine builders so he can run the fuel injection of his dyno.
I've modified a stock sending unit to have a 3/8 out main line and a 5/16 return line. I plan to run two  pre bent main fuel lines 3/8 & 5/16 and interrupt them where I have to for the pump etc...
« Last Edit: June 02, 2014 - 08:38:14 PM by anlauto »
Offline anlauto
« Reply #130 on: June 03, 2014 - 02:09:49 PM »
Tuesday 06/03/14  4 hours === 61 hours Total
Here's what we have:
Brand new 4:10 gears on a new sure grip.
Wilwood 4 piston disc brakes with internal parking brake
Hotchkis rear sway bar
Hotchkis tuned Fox shocks
Hotchkis 1" lowering rear springs
17" Year One Magnums on 275/50R/17 Nittos
These pictures are of approximate ride height as per customer's request.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #131 on: June 03, 2014 - 03:27:19 PM »
Sweet! I put the exact same tires on 17" TT II's on my '71 and they look really good.  I did have to massage my rear inner 1/4's to give the big meats some wiggle room.  Did you have any problems?
Offline anlauto
« Reply #132 on: June 03, 2014 - 04:04:45 PM »
YES...it's very very close.....For some reason, closer on the passenger side which has a reproduction quater panel. :clueless: I'm going to trim it an 1/8" or so...
Offline dfrazz
« Reply #133 on: June 03, 2014 - 04:23:31 PM »
Exactly what I had to do.  They still look really good.  I have 255/50/17's on the front and had to roll the front lip edge a bit, again especially on the passenger side.  Also if you go to complete wheel lock to the right it just brushes the frame rail, but not much.
Offline dutch
« Reply #134 on: June 03, 2014 - 04:27:11 PM »
looks great  :2thumbs:
*** Bart ***
