Author Topic: This just in....ALL DONE!!!  (Read 61849 times)
Offline anlauto
Re: This just in....UPDATE
« Reply #165 on: July 23, 2014 - 09:43:22 AM »
Tuesday 07/22/14  3 hours === 80 hours Total
Started assembling the engine to K Frame and finishing out the engine. I had the TTI headers custom coated in "cast grey" to further the SHEEP'S Clothing look. Also order MARCH supertine pulleys custom powder coated in black.
I really like the mixture of "stock" appearing details with a MONSTER lurking underneath :22yikes:
Offline anlauto
« Reply #166 on: July 23, 2014 - 09:46:00 AM »
You'd never guess this thing has a "496" stroker kit, aluminum heads, intake and water pump...plus it's fully rollerized. :2thumbs: topped off with a Holley TERMINATOR fuel injection system... :scared:
« Reply #167 on: July 23, 2014 - 10:25:42 AM »
Looking good!  :2thumbs:
Offline Ravage
  • 1974 318 'Cuda
« Reply #168 on: July 23, 2014 - 10:29:04 AM »
Oooooh, shiney!   :bananasmi
"I flipped off a box of kittens once..." (Tycho on being evil)
Offline ammo
« Reply #169 on: July 23, 2014 - 10:31:12 AM »
 :ylsuper:
1973 dodge challenger
Offline RusTy/SE
  • Just havin' fun
« Reply #170 on: July 23, 2014 - 12:27:22 PM »
Alan, I'm out of sequence at this point but while a particular vehicle is having metal work done, do you provide that shop any items for test fitting that will be installed later. This way there are no fitment issues for you as final assembly progresses?
Such as a grille, light bezels, and exterior trim pieces...
Beautiful craftsmanship sir, thank you for sharing your knowledge :2thumbs:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline anlauto
« Reply #171 on: July 23, 2014 - 12:30:57 PM »
Not typically unless it's major surgery around the back glass or windshield, then I'll supply the trim :2cents:
Offline MOPAR FANATIC
« Reply #172 on: July 23, 2014 - 12:32:22 PM »
 :droolingbounce: AWESOME job man..................  :ylsuper:
71 Challenger 340 a/t
2013 Plum Crazy Hemi R/T 6SPD
Offline HP_Cuda
  • Mopar or No Car!
« Reply #173 on: July 23, 2014 - 02:31:46 PM »
Very nice
Offline anlauto
« Reply #174 on: July 23, 2014 - 06:10:14 PM »
Wednesday 07/22/14 2 hours === 82 hours Total
Started the fuel system. This EFI requires 3/8 feed line and 5/16 return line.
Keeping with the "stock look" I fabricated a larger 3/8 line to snake around the distributor, goes through the "dummy" fuel pump and picks up a rubber hose (special fuel injection hose and special clamps) to the main fuel line running to the back of the car.
For a return line...I got a little tricky by making my own three nipple oil breather cap. There is now a solid one piece 5/16 tube running through the breather with the fuel hose connected to each end. Running down the inner fender into the regulator.
That's a MSD coil in disguise, and 8mm FIRECORE wires...
With the shaker in place...It should give off the idea of being stock. :bigsmile:
Offline anlauto
« Reply #175 on: July 23, 2014 - 06:11:56 PM »
I'm going to get rid of the blue elbow fittings....that's all my supplier had at the time.
Offline anlauto
« Reply #176 on: July 24, 2014 - 03:51:12 PM »
Went to install the transmission only to find out they gave me the wrong bellhousing adaptor/reducer ring.....You'd think they would have this figured out by now :screwy:
Looks like more down time :pullinghair:
Offline Despicable Z
  • Mopar Newb
« Reply #177 on: July 24, 2014 - 04:57:54 PM »
That's one sweet sleeper there! Very cool Alan!
1970 'Cuda Project
1969 428CJ Mach 1 Mustang
2008 Corvette Z06 (Heads, Cam, Etc.)
2003 Mustang GT
« Reply #178 on: July 24, 2014 - 07:49:40 PM »
Need some machine work?
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #179 on: July 24, 2014 - 08:46:58 PM »
Wow!
