Author Topic: Fasten Seat Belt Light  (Read 761 times)
Offline jforest1
« on: May 08, 2014 - 08:49:24 PM »
Seems my fasten seat belt light may not be setup completely right...and the wiring diagram seems to only show one wire going to it.   :clueless:
Can someone please tell me the wires that should be connected to it and where they should be coming from?
JF
'73 Cuda 340 Slapstick, A727 Torqueflite Transmission, Edelbrock Thunder Series AVS 1806, Vintage Air Gen IV A/C system
Offline FY1Cuda
Re: Fasten Seat Belt Light
« Reply #1 on: May 09, 2014 - 09:00:24 PM »
There's only the yellow wire going to it because the housing is grounded with a wire that screws into the ceiling frame by the rear view mirror.  The wires go back to the dome light, across to the driver's side C-pillar, down to the inside rocker panel, and forward to the kick panel by the e-brake.  The yellow wire and the blue wire for the "low fuel" light are together in their own harness. The yellow wire makes its way to the time delay relay that also does the ignition switch light (I think), and the blue wire goes to the low fuel relay by the glove box.
Offline jforest1
« Reply #2 on: May 12, 2014 - 01:15:38 PM »
Great info!  Thanks!  :cheers:
JF
