Author Topic: A833 manual transmission question  (Read 1003 times)
Offline Cuda4u
« on: May 09, 2014 - 10:23:13 PM »
I picked up this 70 cuda 1.5 months ago and don't have a maint manual yet. What type of transmission oil does it use. And assume it would be up to level mark with side plug? It is about 4" low if this is the case.
Thanks
Offline CudamanTom
Re: A833 manual transmission question
« Reply #1 on: May 09, 2014 - 10:48:35 PM »
If you do a search thru here or google, you will find various inputs.
I went with gear oil 80-90w.
But others will chime in on their choice.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
« Reply #2 on: May 09, 2014 - 11:36:53 PM »
80-90 GL4  up to the side plug , usually 1 gallon from empty
 GL5 is too slippery for the syncros to work properly
« Last Edit: May 10, 2014 - 06:56:33 PM by Chryco Psycho »
Offline Cuda4u
« Reply #3 on: May 10, 2014 - 11:12:11 AM »
This is interesting. There is automatic transmission fluid in it now. I put a post up about a noise when going very slow ahead or reverse after I drove car first time approx 8 miles and happened after drivetrain was warmed up. I pulled driveshaft to check ujoints. Everything new and no issues. Complete drivetrain is new. I will C/O oil and put in gear oil 80/90. I think I'm in the right direction thanks
Offline Cuda4u
« Reply #4 on: May 11, 2014 - 01:37:12 AM »
I forgot to mention I have the passon overdrive with the A833 transmission. And the oil in it is what passon supplies. I.m low and do not have anylikey none in Alberta. I read some posts on here and I think it would be easier to get the Redline MTL 70/80W. This sounds like the right oil? I appreciate your comments as I'm just learning about this car.
Thanks
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: May 11, 2014 - 12:22:25 PM »
I plan to use Redline MTL which is dang expensive but it's what my tranny guy said would work great.
