News:
If it helps you, the original chrome center caps on my 'Cuda's road wheels are right at 2" high, with the inserts 2 1/4".Bill
Why not wait to see if the bulls-eye sticker will fit on the caps that come with the wheels ?
I will be at the shop tomorrow and I have the bulls eyes for my old 14 inch magnums. I'll see how they fit on the AR 15 inch wheels.
Okay. Did some playing around with it today. I think it can be done, but it would take a little work. Look at the pictures below. This is the back of the original magnum wheel and the hub retainer when removed. The tabs that hold the retainer in place fit down into the grooves in the back of the wheel. The AR wheel does not have these grooves and the hub that is on the AR wheel now is held in by friction. All you have to do to remove the hub from the AR wheel is pull on it and it pops right out. The problem is the tabs. I think that the tabs could be ground, bent of modified in some way to let them slip down into the AR wheel and use friction to hold the hub in place. I will play around with them some more and see what happens.
IIRC the taller center cap is from the late 70's early 80's Aspen/Volare cars. I bought my caps from BE&A. They are very nice!
Mark did some modifications today to see if he could get them to fit and grip in the AR wheel. We both thought that just using longer bolts might have some effects on the brakes, even though the metal is fairly thin. This is with the tabs fully removed. Looks kind of cool.
