Great. Thanks.
Summit Racing sells the VN500 wheels. The specs description says "Lug Nut Seat Style: Conical seat - 60 degree"
BTW - Can you elaborate a little on why you're concerned about the center caps/retainers interfering with the brakes? Certainly the cap won't, but I don't see how the retainer would either, especially since it's seated far enough into the wheel's center bore. Where will you be ordering your caps from?
As long as it's seated in the hole, I'm not worried about the cap at all. I was just going to see what happens if we dont seat it in the hole. Just for fun.
I also want to test some different ways to shape the retainer in the hole to see what works best, bending the tab, etc.
One thing for sure is I'm replacing those cheap plastic caps AR sent with the wheels. The wheels are great but the caps are sad.
BE&A will be where I order the new caps.
