Author Topic: Center Caps? (American Racing VN500 [aka: AR500] Wheels)  (Read 6796 times)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
Re: Center Caps? (American Racing VN500 [aka: AR500] Wheels)
« Reply #30 on: May 22, 2014 - 11:38:36 AM »
Got the new hubs in.  They came with the original style retainers.  Cut off the tabs and they work perfect.  The retainers I ordered from year one for their wheel are too big to fit down in the hole in the AR.
Awesome!  :ylsuper:  Looks great!  I ordered a set of the center caps a couple of days ago from PG Classic for $127.25 (including shipping).  Same ones that BE&A sells, but cost was a little cheaper.  My wheels should be arriving end of this month or first week of June.  The caps should certainly be here by then.  Thanks for doing all the experimentation and for posting the process and results with photos.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline ToxicWolf
« Reply #31 on: May 22, 2014 - 11:49:20 AM »
I really like the way the new hubs look on the wheel. Definate improvement.   :bananasmi
Offline filmsurgeon
« Reply #32 on: June 03, 2014 - 09:46:07 PM »
Got my new wheels last week and have been test fitting them to the car.  The prior owner installed a Master Power Brake (MPB) 4-wheel power disc brake conversion kit.  Although I'm not a fan of MPB conversion kits, I don't have it in my budget right now to change it.  The front wheels fit perfectly with no mods needed.  However, the rear wheels were coming in contact with the brake calipers.  So I had to grind off a little bit of caliper housing material; maybe about an 1/8", but afterwards I have just enough clearance.  Regarding the center caps:  Got mine in today.  They measure 2" tall (perfect).  As far as the retainers, I decided to take a different approach.  After looking at them, I concluded it wasn't necessary to cut off the tabs to get them in the wheel's center hole.  All I needed to do was to bend them just enough to get them in.  With the tabs remaining, it provides a bit more centering and support for the cap and retainer.  I've included photos showing the bend angle of the retainer tabs, and the install.  Hope this helps for anyone looking to take this route.  BTW - the wheels are absolutely BEAUTIFUL, and the center caps are very nicely made repros.  Thanks for all the support.
Offline ToxicWolf
« Reply #33 on: June 04, 2014 - 09:11:36 AM »
Look beautiful.   :bananasmi
Offline filmsurgeon
« Reply #34 on: August 03, 2014 - 03:55:45 PM »
Wanted to post some photos showing the end result.  Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials.  Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/As.  Very happy with the AR500 wheels and the new look.  1,000 times better looking than the Weld Racing Pro Star wheels the prior owner opted for.
Offline ToxicWolf
« Reply #35 on: August 03, 2014 - 04:48:54 PM »
You got that right.   :2thumbs:
