Author Topic: Replacement LED Bulb for Trunk/Cargo light  (Read 593 times)
Offline spamtank
« on: May 10, 2014 - 09:54:25 PM »
Under for what it's worth:
I have a working trunk/cargo light fixture, but often I have the trunk open at a show.  I hate taking the bulb in and out, but figured that it would run the battery down if I just left it on.
I recently replaced the trunk bulb in the 2013 RT with an LED bulb for the same reason.  And I found this bulb on EBAY for ~$8 (http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&vxp=mtr&item=271477201965).  It's a bit larger than the standard bulb, but it fits perfectly in the space.  And it draws significantly less current and generates a lot less heat.
Of course, it won't work for the purest, (if you are a purest, I have an extra bulb for you).  But I like having the light, and it's a good compromise.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline 67vertman
  • Member since 9-23-2005
Re: Replacement LED Bulb for Trunk/Cargo light
« Reply #1 on: May 11, 2014 - 02:14:45 PM »
 :2thumbs: Thanks for the tip!  LEDs have come a long way.
