Author Topic: Question on Plug Wires and Headers  (Read 3731 times)
Offline dpcd67
« on: May 12, 2014 - 11:04:07 AM »
Here is the test stand that I whipped up last week to break in my 340. Don't laugh; I know it looks unfinished but it will only be used once. My question is this; look at the rear two plug wires; they are hitting the header. What should I do about that? thanks.
« Last Edit: May 12, 2014 - 07:05:33 PM by dpcd67 »
1963 Dodge M37 (3)
1967 Dodge WM300 (2)
1971 Plymouth Duster
Bought new in '71; I wanted the Challenger but they were $2850; too much $ so I got the 318, 3 speed on the floor, Twister Duster for $2100.
1973 Plymouth Barracuda
I ain't done yet.
Offline cudabob496
Re: Question on Plug Wires and Headers
« Reply #1 on: May 12, 2014 - 07:15:26 PM »
I made custom lengh wires, that come in from the bottom, to
avoid resting against the header pipe.  You can also use 90 degree
plugs that direct the wires away from headers.
Lastly, I put some aluminum tubing on some of the straight boots.
Cool stand! Chain it down, so it does not take off down the street!
these attach to valve cover bolts.  There's more expensive styles out
there too:
http://www.summitracing.com/parts/sum-890041/overview/
« Last Edit: May 12, 2014 - 11:36:24 PM by cudabob496 »
2011 Kawasaki Z1000
Offline erat340
« Reply #2 on: May 12, 2014 - 11:48:45 PM »
TTI
« Reply #3 on: May 13, 2014 - 12:21:14 AM »
Poor header design !!
 All of the cheap header run that tube right over the spark plug ends , , sometimes a 90* wire end under that tube gives more clearance
Offline Rob C
« Reply #4 on: May 13, 2014 - 06:57:40 AM »
Hey! I'm building a engine test run stand as well. I'm almost done. I'll post a picture later when I get home.
I also custom cut my wire and make use of wire looms. On those headers, I use a cloth like sleeve to protect them from heat. I do not like those headers at all. I use Hooker Super Comp headers. ( My build suites the headers) Or use the TTI's.
'73 Cuda, 360, 4psd & 4.10's
'79 Dodge Magnum, 360, 727, 9-1/4 W/3.55's
Offline hemiken
« Reply #5 on: May 13, 2014 - 07:41:33 AM »
  You can also use 90 degree plugs that direct the wires away from headers.
90* wire end under that tube gives more clearance.
 :iagree: 90 Degree angled plug wire ends will sort out those two plugs from hitting the pipes. :2thumbs:
Offline dpcd67
« Reply #6 on: May 13, 2014 - 11:09:55 AM »
Ok,, I will get some 90 degree wires. These are Hooker headers and I can't buy more expensive ones.
1963 Dodge M37 (3)
I ain't done yet.
« Reply #7 on: May 13, 2014 - 10:11:58 PM »
You will be soon , those go under the steering & will be smashed flat shortly
Offline dpcd67
« Reply #8 on: May 15, 2014 - 02:50:14 PM »
Smashed flat? How?  Are you saying these won't work?
1963 Dodge M37 (3)
I ain't done yet.
Offline Strawdawg
    • Vortex Buicks
« Reply #9 on: May 15, 2014 - 06:28:56 PM »
He is saying they don't have much ground clearance
Steve
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #10 on: May 15, 2014 - 07:09:50 PM »
 :iagree:  I have to have friends handy to lift my front end if I use a trailer because they catch on it when I'm backing off the trailer
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
« Reply #11 on: May 15, 2014 - 10:12:05 PM »
there are 3 header designs that stay above the steering link , TTi , Dougs & Hooker 5115 , everything else goes under the steering link & will be smashed closed in a few miles on speed bumps , potholes etc
Offline dpcd67
« Reply #12 on: May 16, 2014 - 12:46:02 PM »
Crap; I know nothing about headers as you can see.  I will have to run these as long as they last; and try to avoid bumps.
1963 Dodge M37 (3)
I ain't done yet.
Offline cudabob496
« Reply #13 on: May 16, 2014 - 06:59:38 PM »
Could always raise front end by adjusting torsion bars, or buy bigger tires/wheels.
« Last Edit: May 16, 2014 - 07:01:20 PM by cudabob496 »
2011 Kawasaki Z1000
Offline dpcd67
« Reply #14 on: May 17, 2014 - 11:14:30 AM »
I do have bigger torsion bars and I have cranked them up so it does sit higher than stock.
1963 Dodge M37 (3)
I ain't done yet.
