Author Topic: MP Distributor  (Read 529 times)
Offline 72cudamaan
MP Distributor
« on: May 12, 2014 - 09:58:27 PM »
Anyone have any experience with the MP P3690432 distributor? Would it be good on a fairly hot 505 motor? I
hear that it comes with the ability for mechanical advance to 26*. Any validity to this? It doesn't have a lower bushing like a
Firecore or a MSD unit. It's not much cheaper than the other units either. I'm just looking for the most bang for the buck.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Strawdawg
    • Vortex Buicks
Re: MP Distributor
« Reply #1 on: May 12, 2014 - 11:06:51 PM »
I have one-they are built by Mallory.  I forget the max mechanical timing that may be set but I set mine to 20 degs and run 16-18 degs initial.  the springs that come with in are probably a bit soft for a decent engine as the mechanical advance comes in quick...seems like it is not much over 2000 rpm.  I dug around in my junk and swapped in a chevy spring to slow it down a little.  Timing is a bit twitchy in the middle of the curve as well.  Some say this is due to the weights not being heavy enough to give a stable, repeatable curve.
If the the Firecore had been available, I think I would have gone with it if for no other reason than I like the HEI terminals that you can get with it...best idea that ever came out of GM, imo.  I believe it comes with some extra springs and it has an adjustable mechanical advance as well.  I forget the limits on it but I am sure their site probably shows them.  I think it might be a bit better designed unit but I have not seen anyone actually mention one.  I have read they use a couple of ball bearings to stabilize the shaft which gives a more precise positioning with regard to air gap which is nice as well.
I think the MP one is no longer being offered but is available from suppliers.
« Last Edit: May 12, 2014 - 11:35:32 PM by Strawdawg »
