Author Topic: Having a stalling issue  (Read 827 times)
Offline Mark8117
« on: May 13, 2014 - 09:56:28 PM »
Running a 400 BB with aftermarket intake and headers.  727 3spd
Running a 750 Holley DP and an Holley fuel pump.  Electronic ignition
After the car warms up 10 min, it will stall when shifting into gear.  Why?
I have adjusted idle/ timing.  The fuel pump is new as I thought that was the issue.  Carb was just rebuilt and still same issue.   :banghead:
Any suggestions?
Offline 72cudamaan
Re: Having a stalling issue
« Reply #1 on: May 13, 2014 - 10:14:51 PM »
What's the timing set at and the idle as well. First thought is vacuum leak.
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #2 on: May 13, 2014 - 10:16:53 PM »
What is the manifold vacuum both at idle & in gear , could be a powervalve or the idle transfer slot uncovered too much requiring opening the secondary idle a little or even holes in the throttle plates or it could be a timing issue or a problem with the dist advance so it retard as the speeds slow when put into gear
Offline Strawdawg
    • Vortex Buicks
« Reply #3 on: May 13, 2014 - 10:45:40 PM »
Assume it did not do this originally?
Did you make any changes recently?
Steve
Offline cudabob496
« Reply #4 on: May 14, 2014 - 12:15:50 AM »
On a DP, having the four corner idle system set up properly helps a lot.
2011 Kawasaki Z1000
Offline Mark8117
« Reply #5 on: May 14, 2014 - 09:09:19 AM »
Thank you for the input we will check for vacuum leaks and work our way through the list
