Author Topic: Cam and headers.  (Read 872 times)
Offline chongo25
Cam and headers.
« on: May 14, 2014 - 07:06:15 PM »
Picked up a Offy 4 barrel intake for my slant 6  and need advice on where to look for a cam and headers.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Re: Cam and headers.
« Reply #1 on: May 14, 2014 - 07:11:20 PM »
There is a Lot of potential in the 225 , I ported the heads & milled them .100 to increase the compression , there used to be some decent cams from Mopar , Clifford may have some Lunati has some killer Mopar grinds . I have not looked into voodoo cams for the 225 but a call to Lunati would answer some questions . Header maybe Clifford , 6-1
 Hooker has a 520=5602-1 from Jegs
http://www.cliffordperformance.net/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=CP&Category_Code=MY
 I use the Holley 390 4 bbl awesome tunability & very responsive with the 4 bbl intakes , you need to build a brace to support the Hyper intake long rams & it will be difficult to tune using a long ran as the carb never gets heat , but I have out run a ws6 car though 1st & 2nd gear .
« Last Edit: May 14, 2014 - 07:18:43 PM by Chryco Psycho »
Offline chongo25
« Reply #2 on: May 16, 2014 - 08:36:36 PM »
Sorry for the late response. Thanks for the information. What exactly is porting the head s and mill them mean?
Offline jhaag
« Reply #3 on: May 16, 2014 - 09:11:18 PM »
porting=open up the intake and exhaust ports by grinding away some of the metal so they flow better.
milling=cut down the mating surface of the head (to the block) to decrease the size of the combustion chamber therefor increasing compression
love 70 Challengers
Offline chongo25
« Reply #4 on: May 17, 2014 - 07:40:07 PM »
Is that something you take the engine to a machine shop?
Offline cudabob496
« Reply #5 on: May 17, 2014 - 08:18:03 PM »
You can just take the head to a machine shop.
2011 Kawasaki Z1000
Offline chongo25
« Reply #6 on: May 17, 2014 - 08:51:59 PM »
Sweet. Thanks for the info.
