Author Topic: Oil pressure sender won't fit. 440  (Read 478 times)
Offline Ornamental
  • Oslo, Norway
« on: May 14, 2014 - 08:52:17 PM »
I bought a standard oil pressure sender, but it's not possible to install it due to hitting the webbing you can se on the picture.
I had a look at the 383 in widing'cudas 'Cuda, which didn't have those webbings.
Is this another difference between B and RB, or do I have a later block?
Is there another sender unit for this block, or do I have to use a adaptor?
Panther Pink '72 Challenger Rallye.
Grey '70 Challenger R/T
-There are two kinds of pedestrians: The quick and the dead.
***Per Arne***
Re: Oil pressure sender won't fit. 440
« Reply #1 on: May 14, 2014 - 09:02:42 PM »
it is a tight fit but usually fits fine if you are off on the angle it will hit the ribs , or you can use a bushing to raise it up a little
