Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
attaching a vacuum gauge
« previous
next »
Print
Pages: [
1
Author
Topic: attaching a vacuum gauge (Read 624 times)
Scat Pack Fever
Mopars Rule!!!!!!!! Always Have, Always Will
Full Member
Chrysler did it best!
on:
May 15, 2014 - 08:58:54 AM »
Hello
I bought a vacuum gauge to tune my challenger. It has a 360 with an Edelbrock carburator. I am hooking the vacuum gauge to the small port on the front of the carburator on the drivers side. I believe it's called the manifold port. Is this the correct port to use? or do I need to go directly off the intake?
Logged
Strawdawg
Resident
Re: attaching a vacuum gauge
Reply #1 on:
May 15, 2014 - 09:20:02 AM »
Manifold vacuum is fine
Steve
Logged
Steve
www.vortexbuicks-etc.com
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Reply #2 on:
May 15, 2014 - 09:22:25 AM »
Manifold vacuum is correct, you should see constant higher readings at idle or constant throttle that drops off when you suddenly open the throttle.
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
Jesus H Chrysler
Full Member
Reply #3 on:
May 15, 2014 - 10:16:06 AM »
Yes drivers side port or manifold should be the same. If you put it on the passenger side by accident, you'll know it. You'll have zero vacuum unless you open the throttle. That's the vac advance port for the distributor.
Logged
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted. "Jeep is a registered trademark of Chrysler Corporation"
Katfish
Resident
70 Challenger
Reply #4 on:
May 15, 2014 - 10:18:32 AM »
If you have AC that line is already brought inside car.
I'm tapping into it for my 518 install
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
