well either the alt went bad or the voltage regulator , the light could have burned out , or it could be a problem in the dimmer switch , you can test the bulbs with an ohm meter or just use a jumper on the dimmer switch & see if the lights work again , JSrestorations can replace the dimmer switch if needed , often because the dash lighting is so poor many just leave the switch jumped for the best lighting
