Author Topic: Best Alternator  (Read 1312 times)
Offline EMCD
Best Alternator
« on: May 16, 2014 - 12:07:42 PM »
Where and what brand should i pick up a 75 or 100 amp alternator?
Offline HP_Cuda
  • Mopar or No Car!
Re: Best Alternator
« Reply #1 on: May 16, 2014 - 01:21:16 PM »
Which ever you choose make sure to do the alt - relay bypass so you don't fry your dash wiring.
Offline EMCD
Re: Best Alternator
« Reply #2 on: May 16, 2014 - 03:26:18 PM »
Yep, already done. Thanks for the heads up. Any good part recommendations?
Re: Best Alternator
« Reply #3 on: May 16, 2014 - 03:34:40 PM »
I've been looking at Tuff Stuff alternators from Summit.  I don't know what the quality is but they are listed as 100Amp.  I want to go with a black case and they offer that finish.
Offline EMCD
Re: Best Alternator
« Reply #4 on: May 16, 2014 - 06:39:12 PM »
I hear power master sucks.
Offline Fern
Re: Best Alternator
« Reply #5 on: May 16, 2014 - 09:54:32 PM »
Where is that located??
Re: Best Alternator
« Reply #7 on: May 16, 2014 - 10:35:04 PM »
Why would that be?
Ever taken an alternator apart?
Pretty basic internals. Easy to re build.
As long as they're tested before they get sent out the door, they should work fine.
Re: Best Alternator
« Reply #8 on: May 16, 2014 - 10:49:50 PM »
I would talk to a local rebuilder , we had a good local one & he could tweak a stock alt up to about 80 amp output .
 Powermaster should be able to make a good product but ... loose connections , cheap diodes , I have heard of numerous failures
Re: Best Alternator
« Reply #9 on: May 16, 2014 - 10:59:14 PM »
Dixie Restorations is like $300 bucks to restore a numbers Alt back to stock.
That's a little rich. But they definitely do good work.
I had conversations with them recently regarding an alternator to be re done.
Offline footin70rt
Re: Best Alternator
« Reply #11 on: May 16, 2014 - 11:10:49 PM »
Has anyone tried a rebuild kit like this, been thinking of giving the 105 amp kit a shot. With any aftermarket accessories a stock output alternator just doesn't cut it.
http://store.alternatorparts.com/repair-kits-and-upgrade-kits-5.aspx
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Re: Best Alternator
« Reply #12 on: May 17, 2014 - 07:48:32 AM »
I don't know if it's the best or not but I've had good luck with mine from DB electrical. It's been 5 years now with no issues? It was an e-bay purchase.
http://www.dbelectrical.com/c-10748-95-amp.aspx
Offline ShelbyDogg
Re: Best Alternator
« Reply #13 on: May 24, 2014 - 08:33:41 AM »
I have 6 round and square-back alternators in the garage and only one of them charges at 14.5 volts at a 750rpm idle. I put them on my engine stand and tested each one.
That is the one I put on my car.
Test your stuff. If you don't get good voltage at a slow idle, send it back.
