Author Topic: 8 3/4" crush sleeve eliminator  (Read 2366 times)
Offline crash340
« on: May 17, 2014 - 02:29:15 AM »
Has anyone ever posted the detail on installation of the crush sleeve eliminator on here???
Greg
73 Cuda
Brisbane, Australia
Re: 8 3/4" crush sleeve eliminator
« Reply #1 on: May 17, 2014 - 10:50:05 AM »
No that I am aware of , it set up the same as the earlier diffs using the spacer + shims to get the load right on the brgs
Offline crash340
« Reply #2 on: May 17, 2014 - 05:48:48 PM »
Thanks CP, I'm seeing conflicting pinion nut torque settings, ranging from 180-290! And it makes a difference albeit its a solid sleeve, at 180 there is near no drag, at high torque damn pinion is near locked up
Greg
73 Cuda
Brisbane, Australia
« Reply #3 on: May 18, 2014 - 12:56:27 AM »
obviously the high # is too high or there is not enough shims to maintain the clearance needed so add a thin shim or torque to the lower end of the range
Offline crash340
« Reply #4 on: May 18, 2014 - 03:55:55 AM »
yep, got that no problems, the issue is what should the pinion torque actually be for the crush sleeve eliminator set up?
Greg
73 Cuda
Brisbane, Australia
« Reply #5 on: May 18, 2014 - 09:45:26 AM »
not sure  :dunno:
Offline mrbill426
    • All Around Mopars
« Reply #6 on: May 18, 2014 - 04:11:29 PM »
 :popcorn:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline ShelbyDogg
« Reply #7 on: May 25, 2014 - 11:55:14 AM »
Ask Dr.Diff. I bought my sleeve eliminator from him. You can contact him through Ebay, through his auctions.
You should be able to crank it down tight and still get the final rotating drag specs set to the crush sleeve setting.
He includes enough shims to get that, in the kit.
Offline crash340
« Reply #8 on: May 25, 2014 - 03:13:07 PM »
Thanks ShelbyDogg, Cass emailed me the specs, losely, his pinion torque was way up there, the highest in fact, followed by a "but I just hit it with good impact wrench". So it doesnt look like there is any science to it.
its all togeather now so only time will tell if I have it somewhat correct.
Greg
Greg
73 Cuda
Brisbane, Australia
