Author Topic: Need a few questions answered to get my cuda running  (Read 895 times)
Offline Dragon383
« on: May 21, 2014 - 02:15:57 PM »
Hello all,
This winter I started the rewire of my car. I also am putting in Vintage Air.
My first question is, on a 440, which is the output on the water pump and which is the input?  This is for Heater hose connections.  I know which go to the radiator.
Second,
My windows fell out of the track when I would roll them down.  I ordered a kit with the rollers to fix this.  The drivers side is now fixed and working great.  The passenger door has a different sized channel for a window track. It is much too wide and the replacement parts are sloppy inside of it and still fall out.  Is this the right/wrong channel for a 74 barracuda?  I know I helped a friend with his windows (70 cuda) and he had a different style. Is there any easy fix, or do I need to order different rollers/ different channel for that door?
Thanks all
Re: Need a few questions answered to get my cuda running
« Reply #1 on: May 21, 2014 - 06:45:40 PM »
I think you answered your own ?
 the track is too wide & the rollers fall out , must be mismatched parts , something has to be the wrong part
Offline anlauto
« Reply #2 on: May 21, 2014 - 06:48:24 PM »
Yep...different width tracks through-out the years..You can get away with just switching the front track.
Heater hose orientation doesn't matter...
Offline Dragon383
« Reply #3 on: May 21, 2014 - 08:05:15 PM »
Thanks guys.  I know the parts were wrong in the windows, I just didn't know what parts were easier to get. The window kits are like $75 per window!  Are tracks easier to find/cheaper?
Also, forgive my ignorance, but why would heater hose orientation not matter?  Is one not flow into the car and the other flow back out?  I only ask because I have a valve I have to put in for the vintage air and it says put it on one side or the other(sorry I forget and am at work).  Is there a way to check flow direction before I install the valve?
Thanks
« Reply #4 on: May 21, 2014 - 10:55:34 PM »
basically the engine pumps water out through 1 hose through the heater core & it returns though the second hose so neither the engine or heater core cares , the inline valve may be another issue though .
Offline anlauto
« Reply #5 on: May 21, 2014 - 11:01:31 PM »
Yes, sorry...my answer was directed towards a stock application....I don't know what's required for the VintageAir set-up. :dunno:
