Make sure you know what you want , , the block you are looking at might be fine if it is what you want. price is reasonable , if you want to use a hyd roller cam the later block is better , the magnum & LA heads are totally different as well , personally I prefer the LA Shaft style with a more stable rocker system etc but the magnum design has some advantages as well .
As a stroker core you use very little of the original engine anyway , block , maybe heads is about all , everything else is upgraded so if the block is std bore , in good condition & checks out OK it will be fine if you want other features 71-85 are la block , 86 -92 are LA roller cam blocks , 88-92 have the 308 heads , 93 up are magnum , most trucks & vans from 86-until the Hemi should have V8 318 or 360 .
3 spd will live they were std behind 383 as well
